Author Topic: Steering coupler clip  (Read 832 times)
Offline v21jeff
« on: August 07, 2016 - 10:29:49 AM »
Having some trouble with my steer coupling on my 72 Cuda. I know there is a bit of an issue keeping the plate on the coupling, so I found a wire clip that holds it on. Has anyone found that the clip is too short? I have looked a pictures I see that the end of the wires go into the roll pin. I can't see any possible way it can, it is too short. Do I have the wrong one? I bought from Roseville Chrysler
Offline v21jeff
Re: Steering coupler clip
« Reply #1 on: August 07, 2016 - 11:12:08 AM »
This clip is on ebay.     301973061965 item #
Offline solarguy
« Reply #2 on: August 07, 2016 - 12:28:05 PM »
I seem to recall there being 2 differ lengths of these.  Either way, they can be a bear to install
Offline v21jeff
« Reply #3 on: August 07, 2016 - 12:38:16 PM »
Thanks Solarguy. I'm gonna check again when I get home. Ive been looking online, I haven't seen another :eek4:
Offline v21jeff
« Reply #4 on: August 08, 2016 - 07:08:18 AM »
I have answered my own question. The clip is not too short, the coupler is too long. My coupler is 3 1/4". My research says it should be 3".  Why is another question. Also found out it doesnt have one oversized tooth to line up on gear box. that solves my crooked steering wheel problem. Now to figure out how to fix the mounting bolt for steering column under the dash that I broke off. :eek4:
