Author Topic: power windows not working  (Read 1161 times)
Offline droptail
  • KETCH JC
    • droptail
« on: August 08, 2016 - 01:15:13 PM »
My power windows are barely working in front, goes slow then stops, won't raise in rear.
Are the grounds in the white switch connectors a typical source of problem?  They look pretty cheesy flimsy.
I will tear into it to troubleshoot, just wanted to benefit from your experience of typical problems to look for.
Thanks
bought off the showroom floor: '70 Cuda convt - 383 bored/ported, Hemi cam, Rhodes, rollers, Mellings,  MSD, 780 Holley, LT dual 3", lowered, snubber, police chuck, discs, springs, sway bars, B&M, posi, shaker, split 15" rallyes w/295's, leather...
Offline 73_Cuda_4_Me
Re: power windows not working
« Reply #1 on: August 08, 2016 - 01:42:16 PM »
Measure voltage at switch while operating... bet you are getting low voltage... usually the firewall connector power terminals corrode and cause excessive voltage drop... and overheating... search here for alternator bypass and ammeter bypass to get wiring fixed if you haven't done that already...
a member on here makes power relay kits for power windows and headlights...
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline roadman5312
« Reply #2 on: August 08, 2016 - 01:45:05 PM »
Member crackedback makes the relay kit.   :thumbsup:
Offline 1 Wild R/T
« Reply #3 on: August 08, 2016 - 01:45:28 PM »
First contact member Cracked Back, he sells a plug in relay kit  that takes the load off the switches & adds a direct connection to power and ground for the motors...
After that lube the mechanisms & what's the condition of your window felts?
Offline crackedback
« Reply #4 on: August 12, 2016 - 02:27:46 AM »
Thanks for the referrals guys.
I can certainly build a kit for your car.  There are many in service and they work very well.  As close to plug and play as possible using OEM style connectors to trigger and power the relays/window motors.
If you'd like too see an example of my work, here is the thread for a window kit.
http://www.cuda-challenger.com/cc/index.php?topic=110101.msg1126525#msg1126525
« Reply #5 on: August 13, 2016 - 11:57:52 PM »
I have fixed numerous power window system when thee in person , it takes a lot of leaning & lubing & testing everything & adding relays really helps
 harder to do over the internet !!
