It depends what parts you have but Dr Diff has the caliper adapters for the larger 11" Cordoba rotors , if you are replacing parts with new ones anyway there is no reason not to go to the larger rotors , the other catch is you must have 15" or bigger rims to clear the calipers if you do this .
You can use the factory / repro proportioning valve or you can use the 5 line Wilwood adjustable . often the repro & factory ones do not work properly , the Willwood is a better solution but will not look factory
