Author Topic: '71 Cuda - Throttle Cable Bracket  (Read 783 times)
Offline Claudia
« on: August 09, 2016 - 11:19:53 AM »
'71 Cuda w / 440 / 727 Automatic Set-up
I'm trying to ensure that I don't have to take my intake back off by making sure that I have the correct throttle / transmission kick-down cables mounting bracket attached before I bolt my intake on.  Can anyone post up some pictures of their throttle / transmission kick-down cables mounting bracket that gets bolted to the intake?
Offline anlauto
Re: '71 Cuda - Throttle Cable Bracket
« Reply #1 on: August 09, 2016 - 01:11:14 PM »
There was never a 1971 Cuda manufactured with a 440 4bbl 727 auto.
You would have to look at a 1970 set-up. If you have a six pack, then that's a different story.
The brackets go on top of the intake, so you wouldn't have to remove the intake, maybe a couple of bolts.
Offline Claudia
« Reply #2 on: August 09, 2016 - 02:01:44 PM »
anlauto - '71 Cuda w / 440 / 727 Automatic Set-up was just in reference to what I am working on.  I'm not looking for an OE correct picture.  I'm sure that someone out there is currently running a '70 - '74 Cuda with a 440 4 bbl w / 727 automatic.
I understand that the bracket sits on top of the intake manifold (rear two bolts on the driver side) but I do not want to remove these two bolts from my intake at a later date to install a bracket that I can put on now with the intake.  I'm just trying to obtain information on the correct bracket to install.
Offline Moparparts
« Reply #3 on: August 17, 2016 - 06:21:40 PM »
The type of bracket you are going to use will depend on if you are going to be using the one piece later type long rod or the 3-piece rod earlier kick down linkage
