Author Topic: power steering pump and steering gear box  (Read 1603 times)
Offline culp71
« on: August 09, 2016 - 02:53:08 PM »
what type of power steering pump would have been on a 71 340 cuda?
(Federal, Saginaw, with/without res. etc)
where can one find a good complete "kit" to rebuild said pump?
how about to rebuild the box?
« Last Edit: August 09, 2016 - 02:58:17 PM by culp71 »
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: power steering pump and steering gear box
« Reply #1 on: August 09, 2016 - 03:27:32 PM »
Saginaw pump and brackets are readily available.
we can put a package together to include
Saginaw pump
Pulley
Nut
pump cap
brackets
pressure line
return line
we have a local guy that rebuild the steering gears. Are you still in Monticello, MN ?
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline culp71
« Reply #2 on: August 10, 2016 - 08:43:19 AM »
thanks mopardave, but I actually already have all of these items... But uncertain if what I have is correct as it seems everything for a 71 340 cuda is unique.
so here's the pump I have, is it a Saginaw /correct?
where can one find a good complete "kit" to rebuild this pump?
where can one find a good complete "kit" to rebuild the gear box?
« Last Edit: August 10, 2016 - 08:48:09 AM by culp71 »
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #3 on: August 10, 2016 - 12:26:38 PM »
the tear drop is what you have is a newer style Saginaw. it will work , but I believe you should have the oval neck style.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline CUDA JAS
  • vroooooom!
« Reply #4 on: August 10, 2016 - 02:37:06 PM »
rock auto has complete rebuild kits for both the steering pump and the box.
Pump is easy...box..more difficult!
http://www.cuda-challenger.com/cc/index.php?topic=112492.0
http://www.cuda-challenger.com/cc/index.php?topic=109887.0
Jason
74 'cuda 360/727
Just call me a gearhead!
« Reply #5 on: August 10, 2016 - 03:42:54 PM »
You have a later style Saginaw with a press fit pulley.  My 73 uses the reservoir style that Dave posted and has a "keyed" pulley.(nut holds it on)  My guess is that your 71 should have a keyed pulley as well.  I bought my rebuild kit from Advance Auto.  It was less than $20 and came with all new O-rings and a shaft bushing.
« Reply #6 on: August 19, 2016 - 09:41:22 PM »
Omega seals seal kits for them easy to get .
 The Oval neck housing should swap onto your pump if needed
« Reply #7 on: August 19, 2016 - 10:22:36 PM »
I've heard that once a pressed pulley is removed, it shouldn't be reinstalled.  It can work its way off.  Don't know if that's true or not.  When I tried removing a pressed pulley on my latest project it would not come off without a major fight.(even with a puller) I ended up destroying the pulley.
