Author Topic: Traction Bars ??  (Read 8224 times)
Offline 73440
Re: Traction Bars ??
« Reply #15 on: August 11, 2016 - 03:25:50 PM »
That's a great website, makes me want to go and make some.
And they even have Homer Simpson there at the end visiting.
Alright I'm back looking for more education . I have a 440 powered 1970 R/T Challenger . It was a 383 car with a 8.75 differential , it had a open rear end 332 gears . The tire size is stock . I put in a sur grip and the car still wheel hops . Are traction bars my next step ? If so what am I looking for  in the way of a traction bar ?  I do not want to change the gears or the tire size . Thanks  :working:
Defend the 2nd Amendment. Tap-a-Talk
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #16 on: August 11, 2016 - 07:35:02 PM »
Clamping the front sector of the spring pack is what made the difference in 70chall440's case not the slapper/traction bar, simply clamping them helps probably more than a pinion snubber. Shocks and a firm front spring sector will fix your issues. GOOD shocks. you may need to add a half spring to firm up the front sector as well
This would be exactly my approach
Offline BadJoey
« Reply #17 on: August 11, 2016 - 09:12:57 PM »
I,m scratching my head why everyone seems down on air shocks ? My ride is stiff but I like the height . My thought is , as the air shock lengthens that would make the springs stiffer , same as a traction bar no ? The only thing coming to mind as to how they could hurt would be if the car had to squat in back in order to hook up ? I,ll have to give this some thought . I,m going to call summit and talk to a tech . I,m going to try clamping the front section first as suguested . I usally start with the cheapest thing first , within reason of course .
Did 73440 refer to me as Homer Simpson ?
Offline BadJoey
« Reply #18 on: August 11, 2016 - 10:03:20 PM »
Offline 73440
« Reply #19 on: August 11, 2016 - 10:10:42 PM »
No, at the very end of the article I linked to Homer Simpson is animated , that site owner must be a Simpson's fan , as I must be as I am watching The Simpson's right now.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline BadJoey
« Reply #20 on: August 11, 2016 - 10:24:24 PM »
cool  :bigsmile:
this is a lake wood site . Go to pitcher frame 323 .
https://www.youtube.com/watch?v=2rBUuG6okLc
« Reply #21 on: August 11, 2016 - 11:08:45 PM »
Air shocks have no effect on making the springs stiffer  , the spring is the spring the rate is the same , you can re-arc the springs for more height but the rate still will not change at all .
 What air shocks do is to change the load from the spring eyes where it is designed to handle the load on to the frame to the shock crossmember where the load will do damage to the body , you can always tell when air shocks had been on a car at some point as the shock crossmember will have damage .
 By clamping the front section of the springs this will stiffen them reducing deflection transmitting more power to the chassis without wheel hop / spring windup & release  , also adding 1/2 leafs forward reduces deflection even more without changing the ride quality as the rear section is still soft & controls the softness of the ride . this will also allow full suspension travel unlike a snubber on the diff .
Offline 70chall440
« Reply #22 on: August 12, 2016 - 12:23:55 AM »
I cannot speak for anyone else, but I will say the reason I cannot stand air shock is because of the damage they do over time but more importantly they will fail at some point, normally at the least opportune time and depending on your wheel/tire selection may make driving the car impossible without destroying the tires.
That said, it is your car, do with it as you like but know that air shocks will in no way help traction or wheel hop. In fact it could be argued that they will do significantly more damage as the energy from the wheel hop will be transmitted directly to your shock mounting points and will eventually cause them to fail or at a minimum cause damage that will be painful to repair.
Current Mopar
Past Mopars
« Reply #23 on: August 12, 2016 - 12:38:20 AM »
the other fator with air shocks is if you have to use them run separate lines to each shock otherwise the air on the loaded side will go over to the unloaded side & add to sway in corners
« Reply #24 on: August 12, 2016 - 12:41:02 PM »
In addition to what others have said, they just aren't a very good 'shock absorber'. They are really installed by people to increase ride height so they are really more of an air bag.
« Reply #25 on: August 12, 2016 - 08:59:03 PM »
Shocks are air shocks about 10 years old but still hold air . Maybe 3 thousand miles .
I have a pair of Gabriel Air Shocks, BFG T/A Radials and the Yellow Lakewood Traction Bars that are 36 years old (1980) on one of my muscle cars and they still do the job.
Although I decided it's time to replace the tires and shocks very soon due to the age and my Safety!
« Last Edit: August 12, 2016 - 09:03:58 PM by 1970 RT Challenger 1970 »
Offline BadJoey
« Reply #26 on: August 14, 2016 - 10:29:16 AM »
Get rid of those shocks, air shocks are garbage on a good day, get a decent pair of rear shocks, if they are 10 years old,,,, they are old and need replacement.
Are they original springs? if so how many leaves? 4 1/2?
The springs are original and there is 4 1/2 . I came into a extra $ 400.00 at the casino last night so . Hello traction bars and new shocks . The next question is which ones ? Any suggestions remember I have $400.00 .
« Reply #27 on: August 14, 2016 - 10:55:53 AM »
Espo spring
Offline BadJoey
« Reply #28 on: August 14, 2016 - 11:10:06 AM »
Check out this video . I never would have guessed the axle moved this much . When the car wheel hops , the banging I hear is that the tires leaving the ground or is something else hitting .
https://www.youtube.com/watch?v=Wpd3Q8p61cE
« Last Edit: August 14, 2016 - 11:32:15 AM by BadJoey »
Offline BadJoey
« Reply #29 on: August 14, 2016 - 11:26:15 AM »
Here is what I,m looking at for Traction bars and shocks under $500.00 . I know I said $400.00 guess it's back to the casino .  :bigsmile:
http://www.manciniracing.com/catrbarsy1.html
« Last Edit: August 14, 2016 - 11:34:19 AM by BadJoey »
