Author Topic: Not charging  (Read 2788 times)
Re: Not charging
« Reply #15 on: August 14, 2016 - 10:54:18 PM »
If you run with the a Battery in the trunk with welding cable, where do you connect the 10 Gauge wire to? To the trunk or the other end of the cable under the hood? Thanks.
Depends how you did your wiring. Do you have a starter solenoid in the trunk as well as the battery?
Offline shatar4
  • 71 Challenger
Re: Not charging
« Reply #16 on: August 15, 2016 - 09:11:46 PM »
Now that its in, what wire can I remove frome the engine bay? I know the 2 blue wires and green to the voltage regular but is there anything else? I am running the 6AL MSD box.
1971 Triple black 340 Challenger
Re: Not charging
« Reply #17 on: August 15, 2016 - 09:56:10 PM »
Not sure what you mean. The new alt will give you more supply current for your fans. You should, if you haven't already, add a wire from the o/p of your new alt to the battery
Offline shatar4
  • 71 Challenger
Re: Not charging
« Reply #18 on: August 19, 2016 - 02:46:33 PM »
I ran a 6 gauge wire from my new alternator to my battery. What happens to the old black wire that was on the old alternator along with the green, and two blue wires? I know the green wire goes right to the voltage regulator but the solid blue and blue with white tracer goes where? I have done the bypass also. Thanks
Re: Not charging
« Reply #19 on: August 19, 2016 - 03:21:19 PM »
Heavy black stays on the alternator ( stock) Same with the green and blue field wires. Not sure what the blue with white tracer was for? Temp gauge? A/C?  :dunno:
Offline shatar4
  • 71 Challenger
Re: Not charging
« Reply #20 on: August 20, 2016 - 05:52:06 AM »
Why would the green and blue field wires stay on the alt? The external regulator is obsolete.
Re: Not charging
« Reply #21 on: August 20, 2016 - 05:09:34 PM »
Ah I thought you had a stock type alternator still .
Re: Not charging
« Reply #22 on: August 22, 2016 - 02:52:28 PM »
There are threads on converting to one wire alts, but I am not familiar with it.
