Author Topic: hood pin lanyard routing  (Read 1101 times)
Offline culp71
« on: August 11, 2016 - 08:39:25 AM »
71 cuda, where should the lanyard for the hood pins be routed through?...the inner headlight ring hole, outer, mounting hole for upper grill fastener?
« Last Edit: August 11, 2016 - 11:13:02 AM by culp71 »
Offline 73440
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline culp71
Re: hood pin lanyard routing
« Reply #2 on: August 11, 2016 - 03:04:37 PM »
nope, pics is poor at best and text does not indicate on a cuda where it is routed through.
this is a picture I found online showing route used, on this one...
so I have ran them through the inner head light bezel relief that is cut out of grill above light bezel, looks correct but still unsure.
« Last Edit: August 11, 2016 - 03:08:05 PM by culp71 »
Offline anlauto
« Reply #3 on: August 11, 2016 - 03:09:18 PM »
Yea that's correct.... :thumbsup:
Offline culp71
« Reply #4 on: August 16, 2016 - 09:51:25 AM »
under the hood should the lanyard also be routed through the metal tab that comes off the back of header panel?
