Author Topic: 4 speed hard to shift  (Read 1128 times)
Offline dave73chally
« on: August 11, 2016 - 01:25:51 PM »
All brand new parts installed...passon 833, brewers hurst shifter, brewers shift rod kit. Installed the levers on the trans and put into neutral position. Lined up the levers on the shifter mechanism with the dowel pin hole. Adjusted the rods to the correct length and pinned them into the shifter mechanism.
When push down the clutch, it's hard to shift. 3-4 seem ok but 1-2 and reverse are hard to get in, if I can at all. What do I need to look at? I thought I had everything correct but I'm guessing not...
73 Challenger
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: 4 speed hard to shift
« Reply #1 on: August 11, 2016 - 01:29:20 PM »
Unfortunately I have heard this same issue with several of Passon 833's over the last couple of months.  I think a couple were posted here.
« Reply #2 on: August 11, 2016 - 02:06:51 PM »
uhhh, do you have any links? don't like the sound of that...
73 Challenger
« Reply #3 on: August 11, 2016 - 07:32:26 PM »
I assume it is not running  it may shift much more easily while running
Offline Chlngrcrzy
« Reply #4 on: August 31, 2016 - 10:28:34 AM »
Possibly when rebuilt the synchro got turned backwards. i did that once when i rebuilt my own. It would not shift into 2nd.
