Author Topic: Confirm I am 180 out (see pics)  (Read 1359 times)
Offline 73CudaDude
« on: August 11, 2016 - 09:22:30 PM »
Can we get a consensus?
Offline 73CudaDude
Re: Confirm I am 180 out (see pics)
« Reply #1 on: August 11, 2016 - 09:48:01 PM »
**** UPDATE **** Ok, I must be tired.  Definitely frustrated.  Went around one more time and it lines up.  I don't know what else to check.  I have replaced the carb, ballast resistor, cap, rotor, wires, plugs, coil, and starter solenoid. Tank and lines have been flushed and filled with new fuel.  Fuel pump pumps good.
When I try to start, I have to hold the pedal to the floor and it will only fire and run while the starter is engaged with the flywheel.  What am I missing?  What else can I check?
Offline turbostang7
« Reply #2 on: August 11, 2016 - 09:49:10 PM »
Could be that it is on the exhaust stroke, pull a plug, put your finger in and when the pressure pushed your finger out, that is th compression stroke. Then start there
1970 Barracuda project in the making!
Offline 1 Wild R/T
« Reply #3 on: August 11, 2016 - 09:49:17 PM »
TDC mark lines up twice once on compression & once at split overlap..... You need to know which one you have...
You need to pull #1 spark plug & put your finger over the hole while bumping the engine over... When you feel compression bring it up to TDC & see where there rotor is pointed.....
Offline anlauto
« Reply #4 on: August 11, 2016 - 10:01:45 PM »
You got a 50/50 chance you're right :smilielol:
Offline 73CudaDude
« Reply #5 on: August 11, 2016 - 10:07:24 PM »
Ok, timing is ok.  Got a good puff when at TDC and rotor is on #1.  So looking at my starting symptoms what else could it be?
Offline anlauto
« Reply #6 on: August 11, 2016 - 10:12:02 PM »
Does it stop running when you let off the key ? Try by-passing the ballast resistor altogether by connecting the two wires together ? :dunno:
Offline 73CudaDude
« Reply #7 on: August 11, 2016 - 10:15:28 PM »
I thought that too, that's why I just put on the new one, but you never know.  Mine is a 4 prong ballast resistor, what jumps to what?  I assume post to post across from each other in the same line right?
« Last Edit: August 11, 2016 - 10:18:17 PM by 73CudaDude »
Offline 73CudaDude
« Reply #8 on: August 11, 2016 - 10:33:02 PM »
Jumped the BR and it starts and runs!!!  What are the odds that 2 are bad?
« Reply #9 on: August 11, 2016 - 11:41:57 PM »
Apparently 100% in this case  :2thumbs:
