Borgeson steering box or fast ratio pitman arms?
Author Topic: Borgeson steering box or fast ratio pitman arms?  (Read 1588 times)
Offline Archialfa
« on: August 13, 2016 - 12:28:48 PM »
What's better improvement for handling: Borgeson power steering box or fast ratio pitman arms (like Hotchkis)? Is it overkill to install both or should I just go for one of these?
The Borgeson box is double the price of the pitman arms so is it really worth it?
1970 Challenger 440 Magnum
Build thread: http://www.cuda-challenger.com/cc/index.php?topic=113902
Re: Borgeson steering box or fast ratio pitman arms?
« Reply #1 on: August 13, 2016 - 12:50:27 PM »
I'd start with the arms first and see how you like it. I'm happy with the stage 3 Firm Feel box and fast ratio arms.... :2cents:
Offline bfunk
« Reply #2 on: August 14, 2016 - 08:51:51 PM »
I installed borgeson gear with tubular upper control arms. Couldn't be happier.
Offline CUDA JAS
  • vroooooom!
« Reply #3 on: August 15, 2016 - 08:51:25 AM »
well neither one is going to improve your handling per say, only make the steering quicker.
I agree with brad, start with the arms.  The fast ratio arms are a bolt in deal, maybe a new alignment to correct the toe, but that's it.  The Borgsen box required some work I believe.
Just my  :2cents:
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline Archialfa
« Reply #4 on: August 15, 2016 - 09:03:06 AM »
Just my  :2cents:
Jason
Yeah, I know it won't improve the handling, I'll be upgrading the suspensions with Hotchkis or QA1 products.
I'm just investigating for now because Borgenson box is not cheap and at the place where I bought my Challenger they highly recommended it. They said it is THE best steering upgrade I can get.
Offline shawge
  • Zoiks!!
« Reply #5 on: August 15, 2016 - 02:03:35 PM »
The only issue I have read and experienced with the Borgesen box is the mounting pad may be off when it was welded. Mine (a first generation box) was off by about 3 degrees and angled the input shaft towards the engine. The coupler probably could have absorbed the angle difference but I fixed the alignment with the use of a re-purposed differential shim.
I do not know if the second generation boxes have the same issue. If you do not want to deal with shimming the box, I suggest buying from a seller that has a very good return policy.
- Jerry
Offline Archialfa
« Reply #6 on: August 15, 2016 - 03:42:54 PM »
Thanks for the info.
The return policy over here is a problem though. Central Europe is not known for Mopar parts stores. ;-)
Offline Alain426
« Reply #7 on: August 16, 2016 - 04:14:55 AM »
I have put a borgeson steering box this summer.  Fit perfectly and with my tuff wheel the feeling is great. No angle in the shaft.
Envoyé de mon Nexus 5 en utilisant Tapatalk
