Author Topic: Speaker Mounting in Dash 70 Challenger  (Read 1574 times)
Offline 69CHARGERMD
« on: August 14, 2016 - 06:44:52 PM »
Does anyone have a picture of there dash mounted speaker ( ie,,,with out the grill cover )... :eek7:
I have one hole for the speaker ( in the middle portion of the dash )....wanted to see how you guys have it mounted,,,,
I bought a after market speaker at Carlise,,,,and I assume it goes "under" the hole in the opening for the speaker ( and does not sit "on top" of the hole for the speaker )
I have a after market dash pad,,,and it is not drilled for anything,,,so i don't want to start poking holes.... :drunk:
thx  !!!
Doug  :2thumbs:
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline ec_co
Re: Speaker Mounting in Dash 70 Challenger
« Reply #1 on: August 14, 2016 - 09:20:49 PM »
I believe they are all mounted from the top. my '70 Barracuda is
'70 Barracuda /6 3spd BH23C0E
If at first you don't succeed, skydiving is not for you
Offline Rdchallenger12
« Reply #2 on: August 15, 2016 - 02:26:18 AM »
I know my 73's is mounted on the top as well, the speaker should have metal "ears" to put the screws in.
« Reply #3 on: August 15, 2016 - 06:10:40 AM »
Offline 69CHARGERMD
« Reply #4 on: August 15, 2016 - 12:04:29 PM »
Thanks everyone,,,,and thank you for the link !
I know i can get the speaker to fit in the dash opening,,,but thinking it might run into the "grill" cover ,,,,hopefully i can recess the speaker a bit if needed.....thx again everyone !
Doug  :2thumbs:
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline cordodge
« Reply #5 on: August 15, 2016 - 12:12:50 PM »
be careful with the cover, they can be brittle. :2thumbs:
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline 69CHARGERMD
« Reply #6 on: August 15, 2016 - 08:38:30 PM »
Thanks Bruce,,, :cheers:
I think i might need to "peal" back some of the dash/foam around the speaker hole,,,to see if i can get the speaker to sit a bit lower in the opening,,,otherwise I can't get the cover back on  :dunno:
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline cordodge
« Reply #7 on: August 15, 2016 - 09:23:42 PM »
I had to do exactly that, I never had a speaker ( radio delete) but there was a bit to much material in that area for the cover to sit properly , no big deal just be careful when you tighten the cover. hope this helps.
bruce
2007  Dodge Ram 4x4
