Author Topic: HEMI Solid Roller Camshaft Valve Lash Setting  (Read 1880 times)
Offline Oldschool
  • Member Since 9-05-06
« on: August 15, 2016 - 10:30:49 AM »
I was assisting my buddy in adjusting the valves on his new 572 HEMI. It has a solid roller cam in it. Anyway, we were rolling along setting the lash just a tick tighter than what the Cam Card said. As we were going through the valves, I started wondering what the lash was supposed to be on my new 572 HEMI build. I had misplaced the Cam Card. Unable to locate the card, I called the cam folks and they pulled up the info and faxed me a copy of the original spec sheet. They said it was a tight lash cam. The correct lash setting is supposed to be .008 hot and as little as zero clearance when cold. That sounds awful tight to me, but he assured me that the cam was designed for the tighter lash setting. Y'all ever heard of this?
Ken  --  In Georgia
Offline rUNCHARGER
Re: HEMI Solid Roller Camshaft Valve Lash Setting
« Reply #1 on: August 15, 2016 - 10:44:49 AM »
Uh, no. Aluminum block and heads, or did he ask?
Sheldon
Offline Oldschool
« Reply #2 on: August 15, 2016 - 11:00:34 AM »
Sheldon
Iron block with aluminum heads.
Ken  --  In Georgia
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: August 15, 2016 - 12:20:03 PM »
With solid gear you will have way tighter tolerances to the tune of .026 - .028 whereas a roller setup can be from .30 - .40 with hydraulic lifters.
Does make you feel a bit creepy doing it this tight and hopefully your PTV calculations are spot on because there is not much room to play with if you are wrong. Unfortunately this just comes with using a solid valve train. If you got this info from your cam manufacturer I would double check since .008 is really so minuscule.
On the upside the benefit of a solid valve train is that you are right on it and get all the benefit of the duration and lift of the cam while losing almost nothing to variances because of hydraulics.
Offline 73440
« Reply #4 on: August 15, 2016 - 02:25:55 PM »
http://www.centuryperformance.com/valve-adjustment-procedure.html
Those who know more than me can verify the link info, but it seems to explain the process well.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline blown motor
« Reply #5 on: August 15, 2016 - 08:56:19 PM »
Cool article for this rookie. Thanks for posting.  :worshippy
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: August 15, 2016 - 09:16:08 PM »
There is several ways you could do it including the EOIC method.
Exhaust open Intake closed
Offline 73440
« Reply #7 on: August 15, 2016 - 11:21:25 PM »
I saw a chart somewhere that shows all the rockers you can adjust with the minimum amount of engine rotations.
You would do multiple rockers per rotation depending on which lifters are on the heel of the cam.
Sounds like EOIC would keep the confusion to a minimum of which are done.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
