Author Topic: 71 Cuda Interior Upper Front-Window & Door Trim. Where do you buy it??  (Read 1032 times)
Offline BobBejeski
  I am doing a complete change over from white a white interior trim,  back to the original black trim.  I found pretty much all the parts I need from Legendary Interiors,  but I cant find these particular trim pieces that go near the headliner,  as well as surround the entire back window, and above the front window as well.    I have been able to find the sail panels as well as the pillar post covers,  but I am not even sure the technical terms for these other plastic pieces.   I have included some pics of the interior.   Does anyone know what these pieces are called,  and where you can buy them.  Repro's are fine, as long as they are good quality.
      Here are some pics,  any help would be appreciated.
Offline Rich G
Re: 71 Cuda Interior Upper Front-Window & Door Trim. Where do you buy it??
« Reply #1 on: August 17, 2016 - 12:06:22 AM »
Are you talking about the window frames and the other pieces along the sides of the roof? They are metal. I'd just blast them and paint them.
Offline anlauto
« Reply #2 on: August 17, 2016 - 07:08:46 AM »
Those are not available in reproduction. You can repaint the one you have as mentioned, or look for another used set.
Offline js29no
« Reply #3 on: August 17, 2016 - 09:31:38 AM »
Glass bead them, it won't mess up the texture. SEM makes A black etch primer and trim black spray paint in A rattle can that works grate. :2cents:
Offline BobBejeski
« Reply #4 on: August 17, 2016 - 11:54:03 PM »
  Great,  thanks for the advice.  Seems like a simple procedure.
 -Bob
