Author Topic: Replaced Exhaust, 70 Challenger 318  (Read 1873 times)
Offline wagenbob
« on: August 17, 2016 - 08:36:29 PM »
Purchased a 318 exhaust from Ebay in 2015 for $315, plus shipping. Seller was sat1966.
My old exhaust was decrepit, to say the least. See the pics for the Diet Dr. Pepper and radiator hose clamp "fix" someone performed.
Clamps were not included, so I supplied new (except for the hanger before the axle). I had to cut off the old hanger mount from the muffler and have my neighbor weld it to my new muffler. I also had to radius cut the tail pipe to clear the rear valance, and had to use longer bolts for the manifold (since the replacement exhaust had thicker flanges). Special thanks to Chrysler for putting those retainer clips on the manifold bolt heads; those did not get re-installed. Anyways, the install was pretty easy. I have a new vs. old comparison photo attached, as well as a shot of the tailpipe after trimming.
Sounds so much better, and I probably shaved 25 pounds in accumulated lead build-up.
« Last Edit: August 17, 2016 - 08:39:33 PM by wagenbob »
-- Bobby
Offline 73_Cuda_4_Me
Re: Replaced Exhaust, 70 Challenger 318
« Reply #1 on: August 17, 2016 - 09:18:22 PM »
Congrats on the updated exhaust system! Looks like you eliminated a few 'restrictions' with the update... I'll bet the 318 breathes a bit easier now!  8 )
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline wagenbob
« Reply #2 on: August 17, 2016 - 09:48:38 PM »
Very smooth. It took some time to re-calibrate my sense of RPM to motor sound.
-- Bobby
« Reply #3 on: August 18, 2016 - 08:52:52 PM »
It looks like the over diff bend was not very accurate & pushed the muffler back a few inches .
 Glad you made it fit OK  :2thumbs:
Offline wagenbob
« Reply #4 on: August 18, 2016 - 10:27:49 PM »
I forgot to mention that part... we had to modify the over diff section because it was kicking the muffler into the fuel tank. Made a small cut, bent, and welded to realign. It really helps having a neighbor who can weld!
The tailpipe piece added about an inch over the previous length, so all in all, not bad.
-- Bobby
