Author Topic: Weird Brake problem  (Read 6211 times)
Re: Weird Brake problem
« Reply #15 on: August 18, 2016 - 11:17:22 PM »
But If I understand brakes correctly...The caliper's piston and flex hose and line are all full of fluid...when you press the brake pedal more fluid tries to enter the same area causing pressure....it's not like there's a large open cavity that fluid has to fill...so I'm not certain where the volume of fluid comes into play.... :clueless:
However...I don't know what I'm talking about, and that's why I have a mechanic  :banghead:
The way I'm looking at this is based on observation of most every front brake pad set I've replaced down through the years..The left side virtually always has more wear than the right... WHY?  I've been told that the line to the left side is shorter & offers less resistance than the right..makes sense to me even if the difference is imperceptible to the driver it's obviously there .. OK so you exaggerate the difference what's gonna happen?
As far as explaining why pressure doesn't go down with some restriction I'd use the straw in the milkshake as an example.. bigger straw you can suck more shake through than a small straw given that you suck with the same effort... of course I could be wrong...LOL
« Reply #16 on: August 19, 2016 - 08:35:42 AM »
Pressure won't go down with restriction, but will make it take longer to reach pressure. So you will see the same pressure but reaction time will change. With hydraulics, flow is speed and pressure is strength.
I believe Bullitt is on the right track. With a blockage, flow is reduced, the pass side will catch up but you already released the brakes because of the left locking up.  :2cents:
Offline anlauto
« Reply #17 on: August 19, 2016 - 10:53:50 AM »
I just called him and changing the rotors made no difference.
I just read him dodj's reply and the next thing he's going to try, is making a makeshift brake line going from the "T" block to the passenger's side flex hose.... :screwy: then bleed that
He did mention that they did have "nice" flow on both sides while bleeding the brakes...
Offline CUDA JAS
  • vroooooom!
« Reply #18 on: August 19, 2016 - 11:04:12 AM »
Are you sure he is using a Disc / Drum MC and not a Drum / Drum MC.
Not sure it would cause the problem, but you never know.
Jason
74 'cuda 360/727
Just call me a gearhead!
« Reply #19 on: August 19, 2016 - 11:06:52 AM »
there really is very little fluid movement , less than 1 oz so even restricted I cannot see it making that difference just for a split second at most .
 take a caliper to the pistons & make sure they are the same diameter , that will change the clamping pressure . They should be the same diameter but what if they  are not ?
 the front splitter block could be a problem but why have the same flow & pressure if it is restritive there ?
« Reply #20 on: August 19, 2016 - 03:23:56 PM »
Just a thought...? what if the piston oring was on backwards in one caliper? It wouldn't retract the same? I guess it would leak though?  :dunno:
He did say he tried different calipers though?  :clueless:
Offline 734406pk
  • Andy
« Reply #21 on: August 19, 2016 - 06:40:49 PM »
Nice equal flow while bleeding the brakes should indicate that the brake lines are ok. A restriction in a brake line usually will make one caliper slow to apply and also slow to release, (stuck caliper symptom). If this were the case, a separate pressure gauge, one on each caliper, should show a lag in pressure drop after the brake pedal is released when compared to the opposite side IMO.  How are the front tires? Tire pressure equal? Check to see if the tread pattern is directional and one tire is on backwards. Maybe try swapping left/right front tires?  Its a long shot.
Offline 1 Wild R/T
« Reply #22 on: August 19, 2016 - 07:31:05 PM »
Might be time to invest in a new tool....
http://www.autoserviceprofessional.com/article/94527/tool-review-disc-brake-analyzer
It's measure brake pressure, but not the fluid pressure the actual mechanical force applied by the pads...
Offline 73440
« Reply #23 on: August 19, 2016 - 07:41:58 PM »
The problem I had with a hose was not on a brake line per se, but what happened was  the internal lining of the hose had torn inside and acted like a flap blocking pressure in one direction.
Are the flex lines new?
« Last Edit: August 19, 2016 - 07:44:06 PM by 73440 »
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline dakota
« Reply #24 on: August 19, 2016 - 07:57:27 PM »
A different angle: a while back, I changed the brake booster on my brother's car.  I didn't get the length of the threaded shaft on the booster quite right (too long), which kept the piston in the master cylinder from completely retracting when the brake pedal was released. The holes in the piston that are supposed to line up to release the brake line pressure were covered.   Once the caliper started to drag, it heated up the fluid stuck in the line which caused even more drag, particularly in the shorter brake line (driver's side) to the point where the driver side front caliper locked.   After pulling the master cylinder off the booster and turning the threaded post on the booster in a couple of turns, the problem went away.
Offline 734406pk
  • Andy
« Reply #25 on: August 19, 2016 - 07:59:45 PM »
Yes, the hose flap acts like a check valve.
Offline AARuFAST
  • AARuFAST
« Reply #26 on: August 19, 2016 - 09:32:22 PM »
Maybe not brake issue.  Check all of the front suspension..A bushings, tie rod, shock. bearings.  :2cents:
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
« Reply #27 on: August 19, 2016 - 09:35:18 PM »
You could install a piston backwards it would hold a lot more fluid but would act the same .
 I have seen the torn inner lining problem before also but this seems to be releasing OK just appling differently .
 If they are ordering the same part #s the piston size could be different though
Offline spamtank
« Reply #28 on: August 20, 2016 - 11:35:31 AM »
 :popcorn:
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline 73_Cuda_4_Me
« Reply #29 on: August 21, 2016 - 09:04:29 PM »
What make / model Mopar?
Wheel bearing adjustment will affect braking, as will worn inner bushings on caliper mounting pins (lets caliper assembly tilt adding mechanical leverage to pad force)...
 :2cents:
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
