Author Topic: Weird Brake problem  (Read 6218 times)
Re: Weird Brake problem
« Reply #30 on: August 21, 2016 - 09:07:52 PM »
 :popcorn:
Come on Alan, the suspense is killing everybody...
 :popcorn:
Good popcorn though....
Offline anlauto
« Reply #31 on: August 21, 2016 - 09:14:41 PM »
Still not fixed. I had a chance to drive the car Friday and it's not that bad under normal driving...it's a hard stop that you notice it pulls hard.
All the suggestions made here are great ones and pretty much all have been checked and ruled out. Only thing left is to swap out the passenger side brake line and or the portioning valve altogether, which really doesn't make sense.
Offline spamtank
« Reply #32 on: August 21, 2016 - 10:16:12 PM »
I struggled with my brakes for 3 months.
Turned out to be the proportioning valve for me in the end.  Good luck.  I know the frustration.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
« Reply #33 on: August 21, 2016 - 10:18:23 PM »
Is the proportioning valve an original or aftermarket?
I had Ramman re build mine as I heard the repro's had issues.
Offline anlauto
« Reply #34 on: August 22, 2016 - 06:49:50 AM »
It's a reproduction...
Offline HP_Cuda
  • Mopar or No Car!
« Reply #35 on: August 22, 2016 - 03:03:13 PM »
Replace the prop valve with a known good one and test drive.
 :2thumbs:
Offline roadman5312
« Reply #36 on: August 22, 2016 - 04:58:24 PM »
  Since its only under hard braking I lean toward a suspension issue. Like movement of an upper control arm (bushing), strut rod bushing, etc.   :2cents:
Offline anlauto
« Reply #37 on: August 22, 2016 - 05:03:47 PM »
All that is 100% new and double checked....
If you drive slow on gravel and apply the brakes slowly, the one wheel starts to slid on the gravel...
Offline roadman5312
« Reply #38 on: August 22, 2016 - 05:06:30 PM »
                         Well that blows my theory   :roflsmiley:
« Reply #39 on: August 22, 2016 - 08:00:22 PM »
Seeing as you said the calipers were changed for different ones, the prop v and line is all you have left. Are there two outlets on the prop v for the front brakes or one? If it is one, change the line.  :2cents:
Offline 734406pk
  • Andy
« Reply #40 on: August 22, 2016 - 08:10:19 PM »
Its a process of elimination. Change the PV or LF brake line, whichever is easier first. BTW how are the rear brakes working? Do they contribute to stopping the car? Just want to make sure that the front brakes are doing all the work alone.
Offline Cudakiller70
« Reply #41 on: August 22, 2016 - 08:11:16 PM »
Check brake hoses for bulging :dunno:
The above is just my opinion
John Adams
Offline 734406pk
  • Andy
« Reply #42 on: August 22, 2016 - 08:23:02 PM »
I'm pretty sure they were replaced earlier w/ same issue. There is not much else left to change.
« Reply #43 on: August 22, 2016 - 08:51:58 PM »
To really think outside the box, are the front tires the same?
Offline blown motor
« Reply #44 on: August 22, 2016 - 09:23:37 PM »
If we're thinking outside the box what about wheel bearings. A bad bearing could cause the wheel to turn hard requiring less braking to lock it up.
