When my car is warmed up, then allowed to idle, the rpm will
all of a suddent drop to between 100 and 300, that\n the engine
will be shuddering. If I pump the throttle at that time, the engine
will go back up to normal idle of 1200. Then if I wait a while,
cycle will repeat. Also, was getting the shuddering and idel around
100 to 300 when trying to start the car to. Not sure if its
distributor related, or if I need to take the carb apart. Engine is 15 years old.
Maybe something else is worn and needs replacing. Out on the road, it runs fine.
