Author Topic: Something weird going on  (Read 46630 times)
Offline 734406pk
  • Andy
Re: Something weird going on
« Reply #135 on: November 23, 2016 - 09:37:07 PM »
OK. How does the engine run at say 1200 rpm?
Offline 73440
« Reply #136 on: November 24, 2016 - 12:24:37 AM »
cudabob496, I bought and have never used an MSD pro billet distibutor , Digital 6AL and 8.5 plug wires for 440 , went with Revnnator system instead, I can send to you to try and see if it helps your problem if you'd like
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 73440
« Reply #137 on: November 24, 2016 - 12:43:12 AM »
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline cudabob496
« Reply #138 on: November 24, 2016 - 01:04:09 AM »
very kind! If MSD sends my 6AL Digital back and says its working fine, I may borrow your
box just to see if solves problem, should I have no more answers.
2011 Kawasaki Z1000
Offline 73440
« Reply #139 on: November 24, 2016 - 01:17:19 AM »
Good deal, just let me know if its needed.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline cudabob496
« Reply #140 on: November 24, 2016 - 03:01:44 PM »
can rev past 1000 rpm, then it dies immediately.
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #141 on: November 24, 2016 - 03:09:01 PM »
Can you set your idle stop screw to hold 1200-1300 rpm?
« Last Edit: November 24, 2016 - 04:23:09 PM by 734406pk »
Offline cudabob496
« Reply #142 on: November 24, 2016 - 04:52:20 PM »
no, have it set so just very small amount of transfer slot is visable.
it just flat don' want to run at all.
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #143 on: November 25, 2016 - 05:40:09 PM »
Your AFR reading before the engine stalls indicates a lean condition for some reason, IMO.  What do you think?
Offline cudabob496
« Reply #144 on: November 25, 2016 - 06:04:46 PM »
I considered some kinga fuel blockage, but couldn't find any.
Electronics may be so screwy, that the AFR readings could mean nothing.
The very first thing I suspected was the 6AL box, but talked with MSD,
and they said the tach needle hovering around 200 rpm would not be caused by the
6AL.  If the 6AL comes back with a repair, they were wrong I guess.
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #145 on: November 25, 2016 - 06:55:11 PM »
FWIW, I have found that whenever there is an electrical issue that fails to provide (properly timed) spark to a cylinder(s), it always drives the AFR to "Rich", which makes sense as the air/fuel charge exits the exhaust in a unburned state (high HC). We'll see what happens after MSD has checked out the 6AL. I hope that's it!
Offline cudabob496
« Reply #146 on: November 25, 2016 - 09:06:02 PM »
ya, if not it, start walking down all the wiring.  Then start over!
2011 Kawasaki Z1000
Offline cudabob496
« Reply #147 on: December 02, 2016 - 08:08:00 PM »
haven't heard from MSD, but noticed my Visa was charged $43.
Which is the total for them to look at it plus mail it back.
Thinking I might get it with a note that says "couldn't find anything"
should see it tomorrow or Monday I suppose!
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #148 on: December 02, 2016 - 10:49:56 PM »
Maybe true but we will see when you get the 6AL back. At least you know the ignition amplifier is ok.
Offline cudabob496
« Reply #149 on: December 03, 2016 - 02:57:59 AM »
Then I will wonder why my test of it, per MSD instructions, did not work correctly.
Will know soon!
2011 Kawasaki Z1000
