Author Topic: Something weird going on  (Read 46654 times)
Offline 70chall440
Re: Something weird going on
« Reply #165 on: December 13, 2016 - 01:17:53 PM »
I am using a Blaster II coil and it seems to work ok.
Current Mopar
Past Mopars
Offline 734406pk
  • Andy
« Reply #166 on: December 13, 2016 - 10:35:12 PM »
Me too, no problems FWIW.
Offline cudabob496
« Reply #167 on: December 15, 2016 - 05:02:34 PM »
OK, after bugging MSD 4 more times, they sent me out to the car in the garage,
and on the phone, we diagnosed the issue. When all is energized, I tapped the white
wire (which is not in use) to ground, and got a spark, so they say the coil is good.
Looking for a spark between the violet and green wires coming from the MSD box, and going to
the dist, I shorted them looking for a spark, and got none.  MSD now believes, since no spark observed,
the magnetic pickup circuitry in the box is bad, so the box is going back to MSD, even
though I just got it back, having been told everything was good. Wah!!
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #168 on: December 15, 2016 - 05:53:59 PM »
Wait a min, can't the magnetic pickup in the distrib also be the problem?
Offline 70chall440
« Reply #169 on: December 15, 2016 - 07:13:03 PM »
Man that sucks, but you are making some progress it seems.
Current Mopar
Past Mopars
Offline cudabob496
« Reply #170 on: December 15, 2016 - 07:28:40 PM »
replaced that, but the MSD test on the 6AL box is done with the dist disconnected.
2011 Kawasaki Z1000
Offline 73440
« Reply #171 on: December 15, 2016 - 11:18:37 PM »
I am away from the 6AL and distributor for a few days and could send on Tues if you need them.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline cudabob496
« Reply #172 on: December 15, 2016 - 11:28:27 PM »
thanks kindly! Let me see if MSD can fix it this time.
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #173 on: December 16, 2016 - 02:10:04 PM »
Sucks you have to send it back again!
 :bricks1:
Offline cudabob496
« Reply #174 on: December 16, 2016 - 05:13:48 PM »
 :bricks1:
new twist, when we decided coil was good, it was due to me touching white wire to ground.
But there is also a white wire from the timing control unit. That is the one I touched to ground, by mistake.
So, I just mailed in 6AL box and coil. If both come back working, then suspecting the timing control
unit may be the culprit.
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #175 on: December 16, 2016 - 06:28:30 PM »
I hope you can find the cause soon, you certainly deserve a break!!
Offline Cudakiller70
« Reply #176 on: December 16, 2016 - 07:21:54 PM »
  :2thumbs: or it could turn into the never ending thread.
The above is just my opinion
John Adams
Offline cudabob496
« Reply #177 on: December 16, 2016 - 07:40:52 PM »
ya, been trying to solve for 4 months. Have rebuilt carb, put in new intake manifold, new
mag pickup in distributor.  New plugs, checked plug wires, etc. Looking like problem is in
6AL box or MSD timing controller. Will be interesting to see what MSD says next.
2011 Kawasaki Z1000
Offline cudabob496
« Reply #178 on: December 17, 2016 - 01:07:17 AM »
If you look at the diagram at the bottom of page 12, that's what
I'm dealing with. I just realized that when I hooked it up this time, I
may not have had 12v red wire from the timing unit energized. So if the box comes
back with them saying it is working correctly, then maybe it wasn't working
correctly this last time because I had it mis-wired. If that's the case, then the
real problem may have been the bad ground on the box, which they discovered
the first time I sent the box in.  Working under the dash with all these wires does
not help, but I may have messed up.
https://www.jegs.com/InstallationInstructions/100/121/121-6420.pdf
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #179 on: December 17, 2016 - 01:25:06 PM »
You have timing control as well?
Hate to throw another monkey wrench but your timing control could also be giving you problems. Didn't the tech's walk you through troubleshooting the timing control as well?
