Author Topic: Something weird going on  (Read 46615 times)
Offline cudabob496
Re: Something weird going on
« Reply #210 on: February 10, 2017 - 04:27:01 PM »
talked with Holley.
because it shuts off so quickly, they think it is an electrical issue.
I tend to agree.
maybe when I release the starter button, that shuts down the engine.
2011 Kawasaki Z1000
Offline cudabob496
« Reply #211 on: February 10, 2017 - 04:38:18 PM »
MSD thinks that my powering the MSD box off the 12v terminal on the starter
relay could be causing problem. though this has worked for me for 10 years, will
try a new starter relay, and powering MSD box off battery.
2011 Kawasaki Z1000
Offline cudabob496
« Reply #212 on: February 10, 2017 - 07:04:35 PM »
moved 6AL power source to battery.
still starts right up then quits when I let go the starter button.
gonna move the 6AL ground to battery as well.
right now the ground is on the engine block, with 3 other ground wires,
in the same bolt hole.
if this don't work, will replace starter relay.
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #213 on: February 10, 2017 - 07:59:16 PM »
Try a basic "hot wire" technique on the ignition system and see how it runs.
Offline cudabob496
« Reply #214 on: February 10, 2017 - 08:16:31 PM »
not sure what that is?
my start button is actually shorting the positive to the ignition
terminal on the starter relay.
« Last Edit: February 10, 2017 - 10:17:46 PM by cudabob496 »
2011 Kawasaki Z1000
Offline 70chall440
« Reply #215 on: February 10, 2017 - 10:29:39 PM »
I believe what he is saying is to turn the power on, then short the rely to engage the starter. To this point, I actually had the reverse of what you are seeing, I could start my car using the "hotwire" technique using a remote starter button, but it would not start at all with the key/switch. I discovered that my ECU and 6AL (white/red wire I think) needed to be connected to connected to something that had power in the start and run positions. That took me on a wild ride of rewiring, fixing, etc.
Current Mopar
Past Mopars
« Reply #216 on: February 10, 2017 - 10:58:08 PM »
Then I'm going to suggest that when you release the start button, you are removing 12vdc from the 6AL. The small red wire no longer has 12vdc on it. You are powering the unit from the battery (large gauge red and black wires), but the small red wire always needs 12vdc when you want it to run. Check your wiring.
Offline 734406pk
  • Andy
« Reply #217 on: February 10, 2017 - 10:59:10 PM »
Bob I will send you a pm on this.  :thumbsup:
Offline cudabob496
« Reply #218 on: February 11, 2017 - 12:03:42 AM »
Appreciate every ones input.
both the large and small red wire are coming right off the battery.
A large wire from the battery goes towards the 6AL box, and splits to the
small wire and large wire. the small wire has a switch on it.
when I turn on the ignition key, and close the small wire switch, the
6AL box red light comes on for 2 secs, then flashes 5 times, as it always has.
Then if I go to start, with either my start button or ignition key, the engine starts, then
quits.  Thinking 6AL box bad, even though its been to MSD twice.
But I still need to run 6AL ground wire to battery.
I need to look at the starting circuit wiring diagram.
« Last Edit: February 11, 2017 - 12:06:07 AM by cudabob496 »
2011 Kawasaki Z1000
Offline cudabob496
« Reply #219 on: February 11, 2017 - 12:17:26 AM »
ok, will look at wiring again, especially white wire
2011 Kawasaki Z1000
Offline cudabob496
« Reply #220 on: February 11, 2017 - 12:19:05 AM »
check out page two:
http://documents.msdperformance.com/6425.pdf
bottom of page 10, white wire is not used
« Last Edit: February 11, 2017 - 12:22:07 AM by cudabob496 »
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #221 on: February 11, 2017 - 02:21:20 AM »
Sounds like your MSD box is dropping 12V power when you let go of the starter button.
Could the button itself be the problem?, short cut the button and start her up and see.
Offline cudabob496
« Reply #222 on: February 11, 2017 - 02:59:40 AM »
yes, that is what its looking like.
yes, have short cut the button, same result.
But dang box has been to MSD twice!!
gonna ground box to battery neg, to see if that helps
2011 Kawasaki Z1000
« Reply #223 on: February 11, 2017 - 06:53:55 AM »
Remove the switches from the cct to test. Connect the small red wire to the battery. Try to start. If it doesn't I'd say you need a new ign box. (You have already verified fuel i guess)
Did you post a pic of your schematic in one of the previous pages?
Offline 734406pk
  • Andy
« Reply #224 on: February 11, 2017 - 08:44:05 AM »
The small red wire on a switch fed directly from the battery positive bypasses your key switch (hot wire). So if the engine starter is engaged (cranking), you have spark and the engine runs, but no spark output otherwise? Check your MSD6AL ground connection. The heavy Black wire needs to be connected directly to the negative battery terminal.
« Last Edit: February 11, 2017 - 08:53:28 AM by 734406pk »
