Author Topic: Something weird going on  (Read 46598 times)
Offline cudabob496
Re: Something weird going on
« Reply #255 on: February 16, 2017 - 08:37:58 PM »
ok, Andy, 734406pk has steered me to the probable solution.
I have on the carb a main body to throttle body gasket from Summit,
part 108-5. I should have used part 108-7, which is a slightly larger bore
and which does not cover up some idle circuits.  When I bought the gasket, it said
for 4150s, and was the only one I saw at the time, and it seemed to fit up real nice,
but, I missed some of the small details. A painful 3 month leasson!
will order new gasket and see what happens.
2011 Kawasaki Z1000
Offline cudabob496
« Reply #256 on: February 16, 2017 - 10:23:05 PM »
so, why does Holley have a part that is ever so different from what is needed,
and even has same alignment holes, and yet blocks some idle passages!
2011 Kawasaki Z1000
Offline Strawdawg
    • Vortex Buicks
« Reply #257 on: February 16, 2017 - 11:28:02 PM »
As, I said a few posts up, I have seen it before. I learned the hard way to check the holes.
Hope that does the trick. Nice to be ready for spring
Offline cudabob496
« Reply #258 on: February 17, 2017 - 02:20:32 AM »
I think what got me was that 1) it came up on summit as what I needed for a 4150, 2) it looked the same in hand,
3) there were lineup tabs on the main body of the carb that the gasket fit over, which to me said it was the right one.
But, live and learn. At least this documented nightmare may keep someone else from experiencing it.
So, in summary, car was acting weird due to bad ground on 6AL box, then Summit sent me a bad coil, then
I put the wrong gasket in.  And, my variable timing unit tested bad. Like I got hit with 4 diff things all at once! Out of service for 4 months, but at least it always ran the previous 25 years, with a few hiccups here and there. But, we will see when I get the right gasket in a couple of days, if all is well.
2011 Kawasaki Z1000
Offline Flatdad
« Reply #259 on: February 17, 2017 - 11:11:41 AM »
Just looked at your thread today, can't imagine how frustrated you must feel.
My knee-jerk reaction for the problems you described was a worn out timing set retarding the cam and idle ignition. You did say the build was pretty old, and it sure fits the symptoms nicely. A retarded cam would make lower vacuum, affecting the idle circuit and late spark would certainly make it difficult to run at lower rpm. When you get the rpm up the spark advance would take over, and enough air could flow across the boosters to activate the cruise circuit, letting it run above 1000rpm. On top of all that, a worn out timing set would show up gradually like you described.
I hope the gaskets and electrical stuff turn out to be the solution though, good luck!
'70 Road Runner-B7 383 Auto, now with more cubes
'97 Ram 1500 Sport 4x4-Bright Red 318 magnum
'67 Belvedere II-Dark Blue 318 Auto, now owned by my brother
'73 Challenger Rallye-B5 318 Auto, had a 360 in it, SOLD :(
'42 Harley Davidson 42WLA-U.S. army green 45ci flathead
'71 Challenger R/T-B5 383 Auto, now 400 powered and rusty!
'86 W100-Yellow 318-2bbl 4x4 4spd, off road toy
'06 Magnum R/T AWD-Red 5.7 Auto, daily driver
Offline cudabob496
« Reply #260 on: February 17, 2017 - 01:20:21 PM »
Thanks. Ya, as Chryco said initially, my problem at first could be pretty much anything.
2011 Kawasaki Z1000
Offline Strawdawg
    • Vortex Buicks
« Reply #261 on: February 17, 2017 - 02:10:51 PM »
Looking them up, it's an easy mistake to make.  I see -5 is for carbs with 1 11/16" throttle bores whereas -7 is for carbs with 1 3/4" bores.  I bet a million other people have made this mistake before you came along.  Probably sold a lot of new carbs because people got fed up and just bought a new carb.
I would concentrate of being happy about all the little things you fixed in the past few months and all the things you learned.  Anyone that claims to never have gone thru something like this is probably awfully new to the game.
Offline cudabob496
« Reply #262 on: February 17, 2017 - 02:34:14 PM »
yes, a somewhat painful experience. Having your car sit in the garage, and not knowing why it will not run, can wear on a person.
I just sent Holley tech an email discussing this issue.
Told them to design carb so wrong gasket cannot be placed on the throttle plates.
And the initial issue of a slowly deteriorating ground on the 6AL box was another mysterious pain in the butt.
« Last Edit: February 17, 2017 - 02:36:19 PM by cudabob496 »
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #263 on: February 17, 2017 - 09:02:26 PM »
This is an easy mistake to make, I have done this myself.  One would think Holley would have caught this and made some adjustments in the Mfg process but IDK. This post may help someone else in the future who is rebuilding a Holley carb::: Check all of the gaskets carefully!
« Last Edit: February 17, 2017 - 09:08:57 PM by 734406pk »
Offline 734406pk
  • Andy
« Reply #264 on: February 17, 2017 - 09:22:10 PM »
I was thinking the same thing (and then some) but the AFR reading went lean. As it turns out the transition part of the idle circuit (1200 rpm+)would have fuel available but not the (adjustable) base idle passage. Crazy isn't it?
Offline cudabob496
« Reply #265 on: February 17, 2017 - 10:08:58 PM »
ya, last time it stalled AFR was 16
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #266 on: February 17, 2017 - 10:41:49 PM »
Yes, the engine is able to get fuel from the transition circuit (unblocked) but not through the metered idle circuit (blocked by the gasket). 1200 rpm or  above, the engine would run from the transition circuit. That would be the hole in the gasket closest to the power valve, prior to the mixture screw.  Do you see it?
Offline cudabob496
« Reply #267 on: February 18, 2017 - 01:17:40 AM »
Yes sir!
2011 Kawasaki Z1000
Offline cudabob496
« Reply #268 on: February 19, 2017 - 07:40:10 PM »
Wow, amazing, took the Cuda out today, and it ran like there was never a problem
in the first place. Thank you God and Jesus, and all that contributed to the solution to
this headache. And we had our first sunny and warm day of the year! I was in heaven.
AFR about 13 to 14, depending on throttle. What else have I learned:
1) if you have a problem, 50% chance its because of something you did.
2) Product techs are valuable to speak to, but they don't always have the answer.
3) The necessity to have all wires separate from each other may be a little overblown.
4) Keeping a record of all you do, as in this thread, allows you to go back and realize
what may be causing the problem.
5) Attention to detail is really important, especially when rebuilding a carb. being able
to see helps too!
Thanks again!
(wonder what the next problem will be on this 45 yr old car?) Gotta feeling
the control arm bushings need replacing!
2011 Kawasaki Z1000
Offline Cudakiller70
« Reply #269 on: February 19, 2017 - 08:42:55 PM »
Sooooo good to hear!   :bananasmi  we all can learn from this, at least I did. Thanks for posting it all.
Bob I'm looking for an AFR, do you like the one your using?
« Last Edit: February 19, 2017 - 08:45:05 PM by Cudakiller70 »
The above is just my opinion
John Adams
