Author Topic: Something weird going on  (Read 46588 times)
Offline jhaag
Re: Something weird going on
« Reply #90 on: November 10, 2016 - 03:25:05 PM »
No. Your issue is 1 of 2 things, vacuum leak, or throttle blades open too far. Too much air is getting into the motor. completely close both front and rear throttle blades. car should not idle at all, unless you have a vacuum leak, or holes drilled in your throttle blades.
love 70 Challengers
Offline cudabob496
« Reply #91 on: November 10, 2016 - 09:04:44 PM »
ya, had the holes for the last 4 yrs. OK, intake with new gaskets going in!
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #92 on: November 10, 2016 - 09:16:13 PM »
 :iagree: I think you have a vacuum leak Bob. Clogged idle air bleeds will make for a rich idle condition, not one of your symptoms. You appear to be lean at idle IMO. Plug all the vacuum lines to PCV, power brake booster etc to test off-engine components. IF there is no change, the intake manifold may have a leak. A smoke machine can be used to test. It is simple to make one, check youtube. I hope it's an easy fix.
Offline cudabob496
« Reply #93 on: November 10, 2016 - 10:33:26 PM »
ya, no power brakes
pcv line has been off before, and just high idles aroud 2000 rpm
this thing will not run below 1000 rpm. sits there and gags and chokes
at around 200 rpm.  Weird.
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #94 on: November 11, 2016 - 08:20:15 PM »
Consider this smoke machine, it really works! It's easy to make or you can buy one from the address listed (kustomsmoke@yahoo.com):
https://www.youtube.com/watch?v=PnU-SY6egr4
 :2thumbs:
Offline cudabob496
« Reply #95 on: November 11, 2016 - 09:13:15 PM »
thanks! will keep in mind!
still putting things back together.
Port matching gaskets is taking a while.
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #96 on: November 12, 2016 - 06:56:13 PM »
That guy is a big kooky but it does seem quite handy!!!
Offline cudabob496
« Reply #97 on: November 12, 2016 - 09:43:47 PM »
ya, he is different
been around a while
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #98 on: November 13, 2016 - 10:20:20 AM »
Here is another example of using a smoke machine to find vacuum leaks etc. On a carbureted engine, i take off the carb and make a blockoff plate using the base gasket as a template (duct tape works too). Connect the smoke discharge hose to a vacuum fitting and look for leaks. You can loosen the rocker shafts to keep all the valves closed for pinpointing say intake ports leaking into the crankcase (OEM steel valley tray/ intake gasket), intake valve leakage, worn valve guides. The uses are endless. A word of caution:: If you use a smoke machine to diagnose an EVAP/fuel leak, use an inert gas like Argon or CO2 instead of compressed air, and test OUTSIDE to be safe.  :2thumbs:
https://www.youtube.com/watch?v=FfiQ7qWiG-M
« Last Edit: November 14, 2016 - 12:17:51 AM by 734406pk »
Offline Cudakiller70
« Reply #99 on: November 13, 2016 - 12:39:10 PM »
That's smart and the dye leaves evidence to find it later. Haven't seen this before thanks!
The above is just my opinion
John Adams
Offline js29no
« Reply #100 on: November 13, 2016 - 04:37:37 PM »
nitrogen is the gas to use as per the owners manual.  ( snap-on )
Offline 73440
« Reply #101 on: November 13, 2016 - 05:42:38 PM »
ya, he is different
been around a while
I have watched some of his other videos and that's him allright.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline cudabob496
« Reply #102 on: November 13, 2016 - 06:24:34 PM »
he has some good advice, if you can get past the sometimes irritating showmanship.
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #103 on: November 14, 2016 - 12:19:07 AM »
Yes, Nitrogen is another INERT gas that can be used!
Offline 734406pk
  • Andy
« Reply #104 on: November 14, 2016 - 12:47:20 AM »
I hope this info helps to pinpoint any leak issues, the UV trace dye is an added bonus too!
