Author Topic: Problem with new tach  (Read 1028 times)
Offline Racer57
« on: August 19, 2016 - 11:32:53 PM »
Last year my tach died so during this past winter I replaced it with an OER from Classic Industries. For the first hundred miles or so it worked perfect. Now it does not move until I've driven 5 miles or so, then it works great until the car has sat for a day or so and then the same old deal.  Kind of like it gets stuck from sitting for very long.  Is this another winter project, replacing the tach again ?  I'm starting to think that OER is related to JC Whitney after all the trouble I've had with various gauges of theirs.
« Last Edit: August 20, 2016 - 04:18:19 PM by Racer57 »
Re: Problem with new tach
« Reply #1 on: August 21, 2016 - 09:14:08 PM »
Remove and reconnect all the connections with your tach. Reinstall with dielectric grease, If no change, you need a new tach.
By remove and reconnect I mean to pull the connector off the tach and push back on. Maybe a couple times just to ensure a good clean connection. Don't know what ign system you have but remake/clean all of the connections. If you have an MSD with tach adapter, then it may be the adapter instead of the tach.
Offline Racer57
« Reply #2 on: August 21, 2016 - 10:51:09 PM »
Stock electronic ignition. I try out what you suggest. It will be a hellva better than pulling that damn dash for the umpteenth time.  :pullinghair:
« Reply #3 on: August 22, 2016 - 12:56:16 PM »
Can you reach the connector on the back of the tach without pulling the dash? I don't remember it has been a while since I had dash issues.
Offline 70chall440
« Reply #4 on: August 22, 2016 - 01:05:05 PM »
You can, just have to be a bit of a contortionist; much easier w/o the seat in place.
Current Mopar
Past Mopars
Offline Racer57
« Reply #5 on: August 22, 2016 - 04:12:24 PM »
When I get around to it, the passenger seat will come out first. From that angle, I can get to almost everything since I don't have a console.
