Author Topic: Starter install problem!  (Read 1974 times)
Offline Wadmin1021
« on: August 20, 2016 - 04:30:24 PM »
440 in our '71 Cuda - just dropped it in today! We have a high torque mini starter and it won't install properly because of a black plastic piece. Anyone else install this starter on their 440 and if so, how? It goes on the top stud okay but the lower bolt won't line up because of this black piece. Suggestions???? Here are pics:
https://youtu.be/OEKt5K71CDM
A couple that plays together, stays together!
'71 Plymouth 'Cuda named Claudia w/ 440 4-barrel and TF AT
Offline rmsolimando
Re: Starter install problem!
« Reply #1 on: August 20, 2016 - 07:24:52 PM »
I used a starter that looked similar. The part that is hitting the engine block can be removed with 2 bolts, assuming is the same unit. The starter wires hook to what is still attached to the starter.
Offline Wadmin1021
« Reply #2 on: August 20, 2016 - 07:56:08 PM »
It looks like you're right! Why is that extended like that? So we can remove that and hook our wires up to the remaining bolts? Here's pics:
Offline 73440
« Reply #3 on: August 20, 2016 - 08:36:46 PM »
 Yes, You can remove that extension if you have it it's just to allow a different place  to attach the wires .
Universal fit starter.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline tman
« Reply #4 on: August 20, 2016 - 09:28:17 PM »
Glad to see the question was asked.  I was thinking of getting the same type starter.  So you remove the whole black plastic extension from the nuts that is attached to what looks like where the solenoid is located?  In essence you are removing both of those longer posts in the black plastic extension?
« Reply #5 on: August 20, 2016 - 10:02:05 PM »
Yes the extender has to be removed to clear , everything works exactly the same when bolted to the lower studs
Offline Wadmin1021
« Reply #6 on: August 20, 2016 - 10:20:00 PM »
Awesome what a huge help and now we know!!!!!
By the way, got rid of the Fram!
« Reply #7 on: August 20, 2016 - 10:35:26 PM »
Make sure the starter mounts squarely on the trans. Some blocks have extra material around the starter that needs to be ground off. My 360 block needed clearancing for that starter to fit. Double check it.
« Reply #8 on: August 20, 2016 - 11:29:24 PM »
Wix  :2thumbs:
Offline Wadmin1021
« Reply #9 on: August 22, 2016 - 01:55:30 PM »
Thanks for help guys - in went in like butter once we made those changes!
« Reply #10 on: August 22, 2016 - 05:31:50 PM »
 :2thumbs:
