Author Topic: Rear sitting to high  (Read 2280 times)
Re: Rear sitting to high
« Reply #15 on: August 22, 2016 - 10:31:36 AM »
That's why I asked about the shackle position.  There was a weird occurrence on another site where the shackle extended "forward" instead of "back" when the car was lowered to the ground.  The rear sat VERY high.  I don't see how that's possible but I remember it happening.
Offline YellowThumper
  • I left the snow for this?
« Reply #16 on: August 22, 2016 - 11:30:59 AM »
I would question the gas shocks.
Remove them both and set the car down without them and see if it improves. Even drive around the block without them to settle everything. The gas pressure may be holding it up. Or could the shocks be overall too long and are bottomed out.
I had one go out on an old Mustang I have it went to full extension and would not return.
Only way I could see the factory leafs being too high is if car was up on stands with the rear hanging for a verrrry long time.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #17 on: August 22, 2016 - 02:50:47 PM »
I think HP is onto something like the springs got re-arched at some point.
318 springs would never sit like that.
Offline Roadrunner420
« Reply #18 on: August 22, 2016 - 05:13:17 PM »
Here is the shackle position.  I put on some old shucks generic shocks today-no difference in height
« Reply #19 on: August 22, 2016 - 05:25:07 PM »
Here is a couple original pictures when I first got the car-then a few before/after paint (keep in mind it had no weight in primer and after paint)
« Reply #20 on: August 22, 2016 - 05:33:42 PM »
Time for different springs I guess  :dunno:
« Reply #21 on: August 22, 2016 - 05:50:14 PM »
thats why I was thinking these with 1"drop -or blocks- 2" would look make it sit better.
