Author Topic: Hard start  (Read 1943 times)
Offline 60K T/A
Hard start
« on: August 21, 2016 - 07:39:06 AM »
When I let my car sit the fuel drains back into the tank now. It never did this before. Before I garaged it (stored for 18 years) it always fired on the first click no matter how long it sat.  It's got me stumped?? BTW I just took it out after another 5 years in the garage.
« Last Edit: August 21, 2016 - 07:57:10 AM by 60K T/A »
T/A, Survivor,
M37B1 Sold
W350
It took about 35 years for the "politicians" to RUIN this country just to line their pockets
Re: Hard start
« Reply #1 on: August 21, 2016 - 08:50:10 AM »
the fuel is very different now m with alcohol etc it will evaporate very quickly
Offline 1 Wild R/T
Re: Hard start
« Reply #2 on: August 21, 2016 - 09:10:46 AM »
Exactly, it's not draining back it's evaporating.... Fuel these days is tailored to work well with fuel injection, carbs aren't a consideration.... EFI keeps the fuel under pressure so it can't evaporate....
Offline cudabob496
Re: Hard start
« Reply #3 on: August 21, 2016 - 04:35:18 PM »
if sat for 5 years, I wouldn't run on that fuel
2011 Kawasaki Z1000
Re: Hard start
« Reply #4 on: August 21, 2016 - 09:15:51 PM »
Offline 60K T/A
Re: Hard start
« Reply #5 on: August 22, 2016 - 06:12:26 AM »
Each time I stored it I ran the carbs dry.  But I guess I don't have to do that any more. Just let it evaporate.
« Last Edit: August 22, 2016 - 06:20:25 AM by 60K T/A »
T/A, Survivor,
M37B1 Sold
W350
Offline rUNCHARGER
Re: Hard start
« Reply #6 on: August 22, 2016 - 11:22:45 AM »
You can fix it by using an electric fuel pump but they look ugly and make noise. I hand primed my Hemi carbs for about the last 7 or 8 years. If you wind the engine over on the starter for awhile to get fuel to the carbs it raises another issue, the lack of zddp in modern oils which will contribute to lifter/camshaft failure.
Sheldon
Offline 73_Cuda_4_Me
Re: Hard start
« Reply #7 on: August 22, 2016 - 02:41:47 PM »
Doesn't the stock mechanical fuel pump have an internal check valve built in? I'm pretty sure my 340 has one...?
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline HP_Cuda
  • Mopar or No Car!
Re: Hard start
« Reply #8 on: August 22, 2016 - 02:44:09 PM »
Well I think electric pumps are bad ass!!!  :bigsmile:
Offline 60K T/A
Re: Hard start
« Reply #9 on: August 22, 2016 - 04:22:15 PM »
Sheldon
I prime my engine by funneling fuel down the carbs to help prevent dry start (PITA). I also use a 50/50 mix of Red Line 5/40 syn and Valvoline VR1 20/50. This also helps to prevent premature wear at start up. The only way I would consider  an elec. fuel pump is if I could install it in the tank.
« Last Edit: August 22, 2016 - 04:28:11 PM by 60K T/A »
T/A, Survivor,
M37B1 Sold
W350
Offline 60K T/A
Re: Hard start
« Reply #10 on: August 22, 2016 - 04:24:47 PM »
Good Point!
T/A, Survivor,
M37B1 Sold
W350
Offline 1 Wild R/T
Re: Hard start
« Reply #11 on: August 22, 2016 - 09:30:51 PM »
Good Point!
There are inlet check valves & outlet check valves... But that doesn't change the fact the fuel evaporates so there's no fuel in the bowls....
Offline cudabob496
Re: Hard start
« Reply #12 on: August 22, 2016 - 11:36:25 PM »
even without check valves, I don't think the bowl design allows gas to drain back out.
2011 Kawasaki Z1000
Offline 1 Wild R/T
Re: Hard start
« Reply #13 on: August 23, 2016 - 12:26:00 AM »
True... :thumbsup:
Offline hooD
  • detroit iron
  • Motor City Made Muscle
Re: Hard start
« Reply #14 on: August 23, 2016 - 03:28:23 AM »
I pour approximately a tablespoon of fuel into the right and left primary carb openings for a quick start.  It sure beats cranking the life out of your battery and starter.
I didn't know that today's fuel blend evaporates so quickly.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
