Author Topic: Ground problem  (Read 829 times)
Offline BIGSHCLUNK
Ground problem
« on: August 21, 2016 - 05:15:10 PM »
I have a weird ground problem with my right  front parklamp. First I thought it was the bulb....  no. Then Figuring the housing was not grounding to the body properly. I cleaned the snot off all the contact surfaces / dielectric grease..... no. The problem seems to be in the way the bulb socket mates to the housing. This appears to me to be a sealed connection. If I lean on the harness at the connection the "right" way I get a good ground. The lamp is bright. It may stay on until I hit the right bump in the road and its out again. Anyone had this issue?  :clueless:  Is there away to open this up and not destroy it ?  :dunno:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Re: Ground problem
« Reply #1 on: August 21, 2016 - 07:53:11 PM »
I've got the same problem. The fix? Put a new harness on the housing. Pg classics sells the harness but there is no way to install it without the tool. Mike at BE&A has the tool and can probably replace it for you. He's getting out of the parts business though. I don't know if he has any harnesses left.
Offline BIGSHCLUNK
Re: Ground problem
« Reply #2 on: August 21, 2016 - 09:34:33 PM »
Hhhmmm almost sounds like I'm better off just getting a new light? I admit I was afraid to start yankin' on the harness.......  :banghead:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline BIGSHCLUNK
Re: Ground problem
« Reply #3 on: August 21, 2016 - 10:21:38 PM »
Ok... so I found the pigtail on PG. whats the tool...  :clueless:  BTW... do you need one or both?  :bigsmile:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Re: Ground problem
« Reply #4 on: August 21, 2016 - 11:39:32 PM »
I have used a starter punch to stake the socket to the housing ,often this is all you need to recreate the good ground contact .
Offline BIGSHCLUNK
Re: Ground problem
« Reply #5 on: August 22, 2016 - 09:15:48 AM »
As usual CP coming up with a good idea!  :grinyes:  I'll try that first.
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
