Author Topic: 340(416 stroker(cuda  (Read 1494 times)
Offline GeorgeTs
  • Newbie
« on: August 24, 2016 - 11:35:37 AM »
I am doing a 340(stroker 416) and between 4 barrel setup and or a 6 pack setup but not sure what to do ,
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: 340(416 stroker(cuda
« Reply #1 on: August 25, 2016 - 10:54:15 AM »
Flash vs. Performance - 6 barrel is mostly for showing off, more unique, and more difficult to keep in tune - 4 barrel is easier to set up, cheaper, and will out perform it on the street but there are a million of them out there.
Offline Cudakiller70
« Reply #2 on: August 25, 2016 - 11:36:13 AM »
:iagree: I have a 340 with 6 pack and I am gong to replace with a 4 barrel. But I'll  probably get the large oval air cleaner for a 4 barrel, still kinda of gives it a similar look.  :2cents:
The above is just my opinion
John Adams
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #3 on: August 25, 2016 - 04:13:48 PM »
6 Barrel Throttle Body with EFI  :drool:
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline dfrazz
« Reply #4 on: August 25, 2016 - 04:29:46 PM »
 :money: :money: :money: :money: :money: :money: :money: :money:
Offline jimynick
« Reply #5 on: August 25, 2016 - 09:39:31 PM »
  Boy, you've got THAT right! Appears to be made out of unobtainium. Oh! To have money!  :banghead:
Offline onebadfish
« Reply #6 on: August 25, 2016 - 09:55:26 PM »
If you have a 6 pack already then go for it. Properly tuned a 6 pack will perform as well or better than any 4 barrel "on the street". Full blown race then a four barrel but on the street the 6 pack works fine. I run a 512 stroker with a 6 pack at 622 plus hp. Runs crisp, idles great at 1100 (kinda big cam) and pulls like a freight train. Slams you back when the end carbs open and NOTHING sounds better than those end carbs screaming!
Offline Road_Runner
« Reply #7 on: August 26, 2016 - 01:42:46 PM »
You are so right, there is nothing like the sound a six pack makes!  Music from Heaven!
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline Mopar Mitch
« Reply #8 on: August 26, 2016 - 03:12:21 PM »
I have both setups:
Eddy LD340/Holley 750 with light weight air cleaner... 30 pounds total (less front-end weight = better handling around the corners... AX/HSAX/HPDE).
Factory six-pack, factory T/A air cleaner... 60 pounds total (but awesome performance... and using adjustable rear baseplate, etc)... great for eye-candy at the shows and pits/races, and MOPAR heritage!
I'd go for the six-pack as its more appealing and awesome.... just be certain to get the adjustable rear baseplate and spend some time (~1-hour) to fine-tune it.... worth it!
Offline Cudaragtop
« Reply #9 on: August 26, 2016 - 03:35:22 PM »
LD340 intake, QF650 4 barrel, Oval 4 barrel Air Cleaner on my 418 C.I. stroked 340
I like the look of the Big Oval Air Cleaner and the larger open filter element makes for easier breathing over the stock round AC with the 2 oval openings.
- Randy D.
« Reply #10 on: August 26, 2016 - 10:50:54 PM »
RPM Air gap & a Proform or QFT 4 bbl  :2thumbs:
 6 pack will not run with it , less power for sure
