Author Topic: Cam Fit  (Read 974 times)
Offline AMXguy
Cam Fit
« on: August 24, 2016 - 06:11:10 PM »
I spun a cam bearing in a 390 years ago from a tight fit and now I'm paranoid.
How good is good enough? I lubed it spun it with a drill for a while.  if you can turn it with 2 fingers I assume that will be good enough?  it still has some resistance.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline 1 Wild R/T
Re: Cam Fit
« Reply #1 on: August 25, 2016 - 02:13:32 AM »
Two fingers should be fine.....
Tight cam bearings on Mopar big blocks are common, the normal fix is to use the old cam to create a clearance reaming tool..... Take the old core & using a die grinder with a cut off wheel slice across all five bearing journals at a 90 degree angle..... Deburr but leave the sharp cutting edge... Insert the cam in the block & a couple turns should remove any tight areas...
Offline jimynick
Re: Cam Fit
« Reply #2 on: August 25, 2016 - 09:58:53 PM »
Har! You SURE you're not from Bruce County?! I could hear my old man talking when I read that.  :grinyes: And just like back then- it made damn good sense once you think about it.  :thumbsup:
