Author Topic: Getting Most HP/TQ Out Of Stock Appearing Engine  (Read 1681 times)
Offline Road_Runner
« on: August 26, 2016 - 01:40:24 PM »
Anyone here have experience with hopping up your engine while maintaining its stock appearance?  I'm thinking stock (or stock looking) intake, original HP exhaust manifolds, maybe a bigger carb that under the air cleaner looks stock enough, and then what can be done on the inside to squeeze another 100+ HP/TQ over the original output.  I would think a stroker would work here but would be limited a lot by how much air the 'stock' intake and exhaust manifolds can move.  Any point to major work on the heads or maybe just a gasket match?  Compression would help, but are there certain cams that work better for this kind of build?  Just curious how much go I could still get out of a 383 or 340 built like this while still appearing stock.  Any good books or article suggestions would be greatly appreciated as well.
Thanks, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline HP_Cuda
  • Mopar or No Car!
Offline Road_Runner
Re: Getting Most HP/TQ Out Of Stock Appearing Engine
« Reply #2 on: August 26, 2016 - 02:58:22 PM »
« Reply #3 on: August 26, 2016 - 10:48:03 PM »
lots to do ,
Stroke the engine
 Port the heads,intake & exhaust manifolds
 match the cam up
 build for midrange tq & you will have a monster
This is what the fast racing is all about
Offline Road_Runner
« Reply #4 on: August 27, 2016 - 02:10:48 PM »
lots to do ,
Stroke the engine
 match the cam up
Hi Chryco, Do you have a guestimate on what a 383-stroked to 489 might do HP & TQ wise?   Would the 440source CNC ported stealth heads (painted of course) I already have be too much of a mismatch?  Would porting the 906 heads be a better match?  I've still got all the original parts so now would be the time to make it 'original' if it's ever going to be.  Thanks, Jim
« Reply #5 on: August 28, 2016 - 12:29:02 AM »
Well lots , I would build more conservative with 430 or 470 CI max , but I have built  a number of these & I have used stock heads as well , I would expect to see 375 ft lbs at the tires [500 range at the crank]on a Mustang dyno which sounds low , trust me it is not mustang dynos are very difficult to get a high # on .
 From the point of view of flow the Stealths should win but using some tricks I have made Stock heads flow very well too , the advantage would be the closed chamber on the stealth heads & being alum you can run the compression in the 10.8:1 range .
 At 500 CI you will need a lot of flow power band will peak around 5400 rpm which is great for a long life street engine with killer TQ
This is an example of fast racing [Factory Appearing Stock Tire] they have to appear stock , manifolds etc  & run through exhaust with factory tires  & running mid 10s to boot   https://www.youtube.com/watch?v=O3qSTsoo_v8
 Crazy tricks throughout the car though to get that performance out of them !
Offline barnett468
« Reply #6 on: September 08, 2016 - 12:25:21 AM »
not much point in spending big bucks on aluminum heads if you are going to run a stock intake.
