Author Topic: CHRYCO BUILD LIST FOR SMALL AND BIG BLOCK STROKERS  (Read 9804 times)
Offline CUDA8U
« on: August 29, 2016 - 01:24:33 AM »
 I am really impressed with PC's knowledge of MOPARS and how to build them,after reading a sh!t ton of his suggestions on numerous posts asking the same questions over and over I think that he should start a post in each category big/small blocks on how to build a stroker motor for the least amount of money :thumbsup:I bet he could write each post with part numbers off the top of his head and where to source them.We as members have a great source of info in him and should be greatful that he loves to help out anyone! Thanks Neil :thumbsup: :wow:
« Last Edit: August 29, 2016 - 01:26:38 AM by CUDA8U »
Re: CHRYCO BUILD LIST FOR SMALL AND BIG BLOCK STROKERS
« Reply #1 on: August 29, 2016 - 05:25:14 AM »
Too many variables , every engine is unique .
 I have built B & RB strokers using every displacement & type of cylinder head available or so I thought ,
 & now they have Promaxx & the new Trick flow heads which I have never used , each combo is different with different combustion volumes pistons & deck heights .
 I have used mostly stock blocks but have built a few with the Max block too where the power would exceed the limitation of the stock block , nothing like using a block that can take over 2500 hp !!
 I have built less small blocks , for the same $$ you can build a big block . I have tried less combos but 340/360 with ported 308 heads make serious power especially stroked to 408/412, I did a 360 W2 , it was silly & worth every penny , the engine had a lobe go flat & tried everything to blow it up rather than fix it , bent the con rods but it held together . I have never done an R3 build but would love to & stick it into a D50 !!
 Cams are the biggest black hole , thousands of choices from hundreds of companies unique to every build , if you are lugging the engine on the highway using 3.23 gear & overdrive you need a totally different cam from an engine with a 3500 stall & 4.30 gears , compression affects everything too , low compression needs to build cyl pressure high compression with the same cam you could uncontrollable detonation & no top end power
 I have used roots & centrifical blowers , all kinds of carbs & built EFI systems but I have yet to build a turbo engine , although that was the plan for the 71 Charger but I never had the funds to build it , it would have been 512 CI with twin turbos & EFI , what better car for room for intercoolers etc using a car with a 7' hood & almost 24 " between the rad & grille !!
 I really need a new project but I cannot narrow down what I want to try next , thinking maybe a Cummins powered rat rod with twin turbo but I cannot see that being very comfortable , I am interested in building a 5.9 with 1600 ft lbs tq at the tires & no detonation problems though !!  It really doesn't matter anyway as I am flat broke as usual .
Probably my best build was a 71 GTX 440 with an 8/71 blower , the whole car cost 15k to build & ran 10.2 @ 134 mph making close to 800 hp & it was reliable .
 I gave the entire car scene up 5+ years ago for health & financial reasons . I have not touched a car or built even 1 engine in over 5 years now , except for the member cars at Carlisle , even though it is my passion . AT least I am not deathly sick 7 months / year here ! Apparently you cannot have it all just one or the other but never both .
Offline CUDA8U
« Reply #2 on: August 29, 2016 - 11:54:33 PM »
  I agree that there are endless combos but I am seeing more and more guys wanting a nice reliable stroker such as a 512 that will keep up to or blow away most of the new stuff! The most common wish list comboI hear are an auto with a decent street stall,3:55 gearing so they can tour and a hot engine that is reliable,I suppose even then the varying weights of diff cars could/would leave ya with numerous cam choices.Most guys I know want a quick street car that can take a beating at the track occasionally.Just for sh!ts and giggles what combo would you put together for a mostly street driven E-body as described above?
Offline NJDevil
« Reply #3 on: September 30, 2016 - 09:26:06 AM »
Thats what Im looking to do right now.  Did anyone ever get a parts list together?
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #4 on: September 30, 2016 - 10:20:40 AM »
I'll throw in the list for my 505ci (could easily be a 512ci), should be a 550hp/600tq build with 10.34:1 compression that will have nice street manners and be pump gas friendly.  Installing in my Charger within the next few weeks.
1975 440 block
Camshaft - Lunati 60312 Hyd Roller Duration @ .050 (Int/Exh): 231/239, Gross Valve Lift (Int/Exh): .535/.550, LSA/ICL: 110/106, RPM Range: 2200-6200
Cam Button - Comp 206
Timing chain - Lunati 94225
Roller Lifters - Lunati 72338-16
Rocker Arms - Comp Roller Set 1621-16
Springs - Comp 925
Heads - Edelbrock 60929
Pushrods - Comp 7774
Bronze Dist/oil pump drive - Mopar P3690875
Head Bolts - ARP 145-3606
Main Studs - ARP 140-5401
440 Source Stroker kit - 440.512.5060
Pistons - 5060 4R 4L
Piston Rings - CR6490-35
Rods - 7.1"
Main Bearings - Clevite MS1795V
Rod Bearings - Clevite CB743HN
Cam Bearings - Clevite SH876S
Oil Pan - Summit 440 6 pack deep pan
Oil Pan Gasket - Fel-Pro 1834
Valve Cover Gasket - Moroso 93055
Valley Pan Gasket set - Fel Pro 1215
T-stat - Milodon 180 high flow 16406
Plugs - Champion RC-12YC
Windage Tray - 440 source for stroker
Bore - 4.350
Stroke - 4.25
Head Gaskets - Fel Pro Perma Torque 8519-PT
Carb - Proform 850 Black Street Series 67314
Intake - Holley Street Dominator HLY-300-14
Water Pump/housing - Mancini High Volume Kit MRE6900KAH
« Last Edit: September 30, 2016 - 10:58:03 AM by dfrazz »
Offline NJDevil
« Reply #5 on: September 30, 2016 - 03:10:24 PM »
1975 440 block
Springs - Comp 925
Rods - 7.1"
Bore - 4.350
Stroke - 4.25
Thanks!  Thats exactly what I'm looking for.  Any idea what the parts cost was approx?  What did you for headers BTW?
Offline dave73chally
« Reply #6 on: September 30, 2016 - 05:42:18 PM »
I have a very similar build. Probably about 7k in parts and machining
73 Challenger
« Reply #7 on: September 30, 2016 - 06:24:34 PM »
Let me see what I can put together for a list
Offline Cudakiller70
« Reply #8 on: September 30, 2016 - 07:12:57 PM »
 :popcorn:
The above is just my opinion
John Adams
Offline dfrazz
« Reply #9 on: September 30, 2016 - 08:17:21 PM »
About $7k in parts.   TTI 1 7/8" ceramic with 3" h-pipe exhaust.
« Reply #10 on: October 31, 2016 - 09:12:57 PM »
Dfrazz, our builds are identical except for heads and bore. Did you fire yours up yet?? You are going to love it, mine is an absolute animal
73 Challenger
Offline dfrazz
« Reply #11 on: November 01, 2016 - 10:32:16 AM »
Pulling the current 440 in the next couple of weeks and hope to have the new engine in and burning rubber before Thanksgiving!
Offline 73cudabr
« Reply #12 on: November 01, 2016 - 03:00:07 PM »
subscribing to this as well. Looks like a few of us getting new power plants.
Offline usraptr
« Reply #13 on: November 21, 2016 - 12:20:42 PM »
I just finished and fired my 512 build.  It's very similar to dfrazz with the following exceptions:
Pro Max aluminum heads (good quality and only $1200)
Lunati Voodoo Hydraulic Flat Tappet & Lifter Kit - Chrysler 361-440 Three Bolt 276/284 Gross Valve Lift (Int/Exh): .513/.533
Holley dominator aluminum intake
PRW rocker arms
Quick Fuel 880 CFM Carb.
TTI polished ceramic headers
(Edited 8-1-17)
Offline dfrazz
« Reply #14 on: November 22, 2016 - 09:08:32 AM »
Here is my 505 - no numbers except it plants you back in your seat. Very happy with this combo, runs amazing in every gear, and pulls as long as you want it to.
https://youtu.be/HIYHRgbeYOI
https://youtu.be/UrF7DdJVZFw
