Hey guys,
I know that title is a mouthful. I'm ready to assemble the timing cover and water pump and have 2 questions.
1. I'm used to a small weep hole on water pumps. In the picture that weep hole is huge and threaded. Is that correct? If so why is it threaded?
2. I've have conflicting torque specs. One says 30lbs on all of the bolts one says 16-18 lbs. Can someone clarify the torque specs on the bolts. Maybe some are different than others. Just want to make sure its done correctly.
Yes I know the timing cover seal needs to be installed. I'm just dry fitting everything first. Thanks
