Author Topic: To stroke or not to stroke?  (Read 3267 times)
Re: To stroke or not to stroke?
« Reply #15 on: September 02, 2016 - 12:41:05 PM »
I have not used them ,
 RHS , Airwolf , W2 /5/8/9 :2thumbs:
 Doing more research the LA X & RHS seem to be the same , good combustion chamber shape & size & @ $1000 for a pair decent price too
http://www.racingjunk.com/Heads/182740843/Mopar-W5-heads-intake-raised-port.html   :bigsmile:
http://www.jalopyjournal.com/forum/threads/new-mopar-4452926-w-5-w5-small-block-heads-blue-core-plugs-340-360-raw-unmachined.964325/ Check out the combustion chamber on these  :thinkerg:
« Last Edit: September 02, 2016 - 01:01:32 PM by Chryco Psycho »
« Reply #16 on: September 02, 2016 - 01:13:49 PM »
Offline 7212Mopar
« Reply #17 on: September 02, 2016 - 03:32:44 PM »
Well to hijack my own thread, what are peoples thoughts on the new Indy LA X iron heads?
John, are you thinking about a 340 stroker?
I will be taking my block down to South Cal next month for the build and has been reading the Hughes 426 stroker kit. It is a little longer than the typical 4" stroke and available in custom forged piston sizes. Take a look and see what you think. BTW, I am going with aluminum heads (lighter) and have the engine builder check them out for me.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Offline 7212Mopar
« Reply #18 on: September 02, 2016 - 03:54:10 PM »
John, some info here. I was looking at this last year before I pulled the engine.
http://immengines.com/indyimmironheads.html
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #19 on: September 02, 2016 - 08:59:30 PM »
Yeah I am trying to decide for the next round on my 340 if I should keep the stock stroke or go stroker. What I like about the Indy heads is they are iron which helps give more of a stock appearance, plus I don't like the overhang on the ends of the block you get with aluminum heads. I was just reading about how hughes modifies the indy heads and those look appealing. Also I plan to retain the 6 pack, so that limits head choices as well.
1996 Dodge Viper GTS Coupe
Offline barnett468
« Reply #20 on: September 08, 2016 - 12:33:18 AM »
You could build a 7500 rpm 340.
Offline AussieMark
« Reply #21 on: September 25, 2016 - 03:47:47 AM »
When you increase the stroke you increase the distance the piston has to travel to complete one revolution therefore the piston speed is increased when this engine is run at high rpm it will not be as reliable as the standard stoke engine the lower the piston speed the less wear and stress.
Offline msbaugh
« Reply #22 on: September 25, 2016 - 07:40:30 PM »
