E-body - 440 Parts
Author Topic: E-body - 440 Parts  (Read 785 times)
Offline Claudia
E-body - 440 Parts
« on: August 30, 2016 - 08:41:03 AM »
440 Springs & Retainers - 60
Mopar Big Block Chrome Valve Cover Hold Downs - 15
440 Throttle Bracket w / Carb Linkage - 40
Mopar 7 Blade Fan w / Thermal Clutch - 120
440 Timing Chain Cover - 25
440 Camshaft - 50
440 Fan Clutch - 15
440 Fuel Pump Push Rod - 20
66 - 72 B-body / 66 - 73 C-body / 70 - 74 E-body LH 440 Engine Support Bracket - 30
440 Flex Plate - 25
440 Oil Pump - 35
440 Oil Pickup Tube - 20
70-71 Mopar Rallye Wheel Center Cap (center disk only) - 3
Mopar Front Shock Mounting Hardware Kit - 10
71 - 74 E-body / 71 - 73 B-body Steering Column Seal Retainer - 18
Mopar Fuel Line Hardware Kit: New, kit is for 3/8” supply line and ¼” return line - 15
E-body Torsion Bar Set: 774 / 775 bars - 40
Mopar Electronic Ignition Module - 10
70-71 E-body Wiper Linkage Pivot - 35
70-74 E-body Heater / Defrost Vent Duct - 40
Floor Heat Shield: 2 sheets – Each approximately 6’ x 4’ - 50
70-72 E-body 4 Speed Brake Pedal Pad - 5
70-74 E-body Standard Dash Light Bar - 40
E-body Rallye Dash Speedometer - 175
E-body Rallye Dash Tach: 7K - 175
E-body Rallye Dash Clock - 175
72 – 74 E-body Rallye Dash Lens - 125
70-74 E-body Ash Tray Support - 25
71-74 B-body / 71 E-body Rear View Mirror - 15
70-74 Barracuda Weather Strip Channel Retainer Trim Set - 75
73-74 B-body Outside Mirror Gasket - 10
70 – 74 E-body Ignition Switch: Missing connector - 15
70 – 74 E-body Key Buzzer Switch: Missing terminal ends - 25
70 – 71 E-body Ignition Key Lock - 15
70 – 74 E-body Turn Signal Switch: Missing connector - 25
Mopar A, B and E-body Upper Steering Column Bearing and Insulator - 25
Mopar Window Crank Handles - 20
Mopar Late 60’s Interior Door Handles: 2 LH handles - 10
Mopar Dome Light Assembly - 30
Holley Blue Electric Fuel Pump - 80
Mopar Trunk Lid Latch Striker - 15
B / E-body Trunk Lid Latch Striker - 20
Mopar Trunk Lid Latch - 20
70-74 Barracuda Trunk Lid Key Lock Latch Lever Hardware - 15
70-74 Barracuda License Plate Light Lens - 10
70-74 Plymouth Barracuda Fuel Tank Filler Neck Tube - 30
71 Barracuda Chrome Grill Taillight Bezel Set - 50
E-body / 440 parts that I need as trade or shoot me an offer if you are interested in anything.  Additional pictures are available upon request.  All prices are OBO.
« Last Edit: September 06, 2016 - 08:54:15 AM by Claudia »
Offline Claudia
Re: E-body - 440 Parts
« Reply #1 on: September 06, 2016 - 08:54:32 AM »
Updated list.
