Author Topic: 8 3/4" Axle Preload  (Read 884 times)
Offline YO7_A66
8 3/4" Axle Preload
« on: August 30, 2016 - 09:05:50 PM »
 Due to some noise in the rear of the car, I decided to check the axle preload. I found the preload at .016"-.021" while rotating the passenger axle and checking it in three places. I reset it to .006"-.009" while rotating the axle in three places.  I assume that this will loosen up a tad over the next couple of drives, so I plan on checking it again.
 Note: My FSM shows .008"-.018" and I have read posts showing that people think that is too loose. Some say .005"-.010", so that is what I aimed as a range.
 Before I test drive it, I am curious what you guys run.
 Thanks
« Last Edit: August 30, 2016 - 09:15:53 PM by YO7_A66 »
Re: 8 3/4" Axle Preload
« Reply #1 on: August 30, 2016 - 09:17:44 PM »
I set @ .010
Offline YO7_A66
« Reply #2 on: August 31, 2016 - 10:01:51 AM »
 Thank you CP!!
« Reply #3 on: September 01, 2016 - 12:14:56 AM »
 :2thumbs:
