Author Topic: How difficult is it to remove and install new tranny cooler lines on a 727  (Read 703 times)
Offline EMCD
SB 727 needs new lines. How hard is it to do DIY?
Re: How difficult is it to remove and install new tranny cooler lines on a 727
« Reply #1 on: September 01, 2016 - 10:58:08 PM »
Shouldn't be ...Just make sure you hold the fitting with a wrench while you tighten them.. I twisted a line once not doing so.
I I'd advise you to disconnect your battery while doing so...
Offline SirRalliart
« Reply #2 on: September 02, 2016 - 06:07:09 AM »
I have a 360 car with a 727 and a previous owner cut off the steel lines and replaced with rubber.  I dutifully bought new SS lines, but they are bent to fit the box.  The last time I had the car in the air, I couldn't figure out the routing and which bends needed to be unbent, so I put them back in the box and decided it was a winter project!
I've since bought a used original service manual from Amazon ($2.99 - LOL), which will make it much easier to tackle the job!
1971 Dodge Challenger R/T (Top Banana)
1972 Plymouth 340 Duster (TX9 Black)
1974 Plymouth 'Cuda360 (Deep Sherwood Metallic)
1978 Plymouth Volare Street Kit Car (#43, 2-tone Blue)
2014 Dodge Ram 1500 (Pitch Black)
2015 Dodge Charger SE (Granite)
2015 Dodge Callenger Hellcat (Phantom Black)
« Reply #3 on: September 02, 2016 - 09:57:51 AM »
The hardest part will be fishing the new lines between the K-member and the engine.  The exhaust and the floor pan will be in the way.  There might be some swearing involved but it shouldn't be too bad.   The lines run right under the power steering belt.  It might be a good idea to remove that belt so there is one less thing for the new lines to get snagged on.
Offline EMCD
« Reply #4 on: September 02, 2016 - 04:14:06 PM »
thanks guys!
