Author Topic: how to remove gear indicator from an original column shift?  (Read 743 times)
Offline miamivice
« on: September 02, 2016 - 06:49:07 PM »
Hi!
I plan to install a floor mounted shifter & console in my Cuda.
The actual column that I got w/ my car is a column shifted column, and I am hoping you guys can tell me what parts I need to do the conversion to get rid of that section w/ the indicator, as this will be a real obviously 'off' looking feature on my interior if i leave it.
Any pictures would also be helpful if you have done this on your car as well.
Thank you!
F
Offline 1970A-66Challenger
Re: how to remove gear indicator from an original column shift?
« Reply #1 on: September 02, 2016 - 08:06:13 PM »
Last year I converted my steering column from column shift to floor shift for 4 speed conversion. IIRC Essentially you need to swap the cast aluminum housing that has the gear indicator and shift lever (two pieces) with those from a floor shift car (three pieces, auto or manual). All other components from the column shift steering column are used.
Neil
« Reply #2 on: September 02, 2016 - 10:37:03 PM »
PM me your e-mail.
I have a really good pdf. file I can forward to you.
« Reply #3 on: September 03, 2016 - 12:58:21 AM »
The part that mentions pulling the key cylinder out:
Put the key in and push the pin in the hole.
Also be very aware how the spring is on the column that's for the lever lock out.
I didn't pay attention when I took it off and it took me hours to find where it connects back.
Offline miamivice
« Reply #4 on: September 03, 2016 - 10:48:04 AM »
thanks for emailing me the rebuild guide, really helpful!!
what other cars/years can i find these 2 pieces from the column that I am looking for?
and now, most important question - does anyone actually extra pieces that they would be willing to let go to help me out?  :thumbsup:
