Author Topic: LED's for Dash Light Bar ?  (Read 5545 times)
Re: LED's for Dash Light Bar ?
« Reply #15 on: September 07, 2016 - 11:18:23 AM »
Thanks.  Didn't know that was there.  It looks like there are enough bulbs of that type to warrant buying 8.
Offline Racer57
« Reply #16 on: September 11, 2016 - 10:12:41 PM »
Installed the LED's.  WOW !!!   I might have to actually dim them at night.   :D
FYI for anyone else thinking about using them........   They will not fit into the metal "cap" that's used for the ash tray light, the light at the bottom of the switches or the far left panel light.
Offline Lbs
« Reply #17 on: September 12, 2016 - 11:23:55 PM »
Got my LED's installed today. Went with the green bulbs and left the blue filters in place. Don't know if any body else had this problem, but the LED bulbs wouldn't fit in the light bar hole. Had to drill it out with a 7/16" bit which also helped make a good ground to the light socket. I expanded the keepers on the sockets and it worked out OK.
Sent from my SM-N920V using Tapatalk
Offline shawge
  • Zoiks!!
« Reply #18 on: September 13, 2016 - 10:14:24 AM »
Are the bulbs dimmable?
- Jerry
Offline Lbs
« Reply #19 on: September 13, 2016 - 10:30:12 AM »
Yeh they are, and pretty affordable also. I got 10, (5 green and 5 blue) on eBay for around $16.00
Sent from my iPad using Tapatalk
Offline Racer57
« Reply #20 on: September 13, 2016 - 04:37:26 PM »
I first thought I would have to drill mine out also. But I used dielectric grease on the panel and they finally slipped in. I also used green bulbs with the blue filter.  :D
Btw, be very careful and make sure the bulb socket does not have any corrosion and put dielectric grease on the bulb. I twisted the base loose from one because it didn't want to twist into the socket.
« Last Edit: September 13, 2016 - 10:46:37 PM by Racer57 »
Offline Katfish
  • 70 Challenger
« Reply #21 on: September 13, 2016 - 06:06:17 PM »
My bulbs were a tight fit, but with a little finesse they all slid in.  No drilling required.
I too left the blue filter lens in place.
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
« Reply #22 on: September 13, 2016 - 07:12:53 PM »
This is going to happen for me too!  ... Just got to squirrel some nuts in the paypal account now hahaha.    I have a bit of a cam so I get that brutal dimming when the thing lopes in reverse and I can't see anything.
Want one?  Got one! ... finally
« Reply #23 on: September 13, 2016 - 09:36:43 PM »
A headlight relay kit will go along way in minimizing that issue.
« Reply #24 on: September 14, 2016 - 11:59:36 AM »
"wantone" your PMs are full.
I got my relay kit from "that guy" on here.(crackedback)
« Last Edit: September 14, 2016 - 12:03:43 PM by burdar »
Offline dizzi1
« Reply #25 on: September 21, 2016 - 01:49:06 PM »
Did anyone add the HVAC and ashtray bulbs also.
They appear to be different so which were used and were they better?
I used the same LED's as pictured above and they work great but not CRAZY brighter?
  JB
Offline shawge
  • Zoiks!!
« Reply #26 on: September 21, 2016 - 02:00:05 PM »
The same BA9S bulbs will work there.
- Jerry
Offline dizzi1
« Reply #27 on: September 21, 2016 - 02:02:28 PM »
Thanks Jerry
I will check it out.
Offline Katfish
  • 70 Challenger
« Reply #28 on: September 21, 2016 - 06:19:13 PM »
No, my ashtray is different, not sure about console.
Offline shawge
  • Zoiks!!
« Reply #29 on: September 21, 2016 - 06:37:01 PM »
 :dunno:  I've got the BA9S in my Challenger - no issues so far.
The ashtray light is #1445 for the incandescent which maps to BA9S in LED.  IIRC, the other bulbs for the console are #1816 (light panel) and #57 (indicators) which also map to BA9S.
You do have to be careful for oversize bulbs especially when they are encapsulated like the ashtray and AC/Heater lamps.
- Jerry
