Author Topic: advice on stubborn lower ball joint?  (Read 2167 times)
Offline DadsCuda
« on: September 03, 2016 - 08:20:42 AM »
I am having a HELL of a time getting the lower bsall joint out. i'm converting to front disc set up and i have tried a pickle fork, a tool that i got a harbor freight that i broke, a hammer, a bigger hammer, pb blaster. i tried with the lower control arm supported with a jack (as suggested by a friend)...with no support from the jack (as a different friend suggested). the torsion bar is loose, but not removed. there is nothing attached to the ball joint, it is simply not coming off the lower control arm.
i have an actual person coming to help me, but once he's back from his vacation, I won't be around for a couple weeks and i just need to see some progress and feel like i'm just either missing a simple solution, or i'm just not hitting it hard enough!
any and all tips and advice welcome and sooooo appreciated.
Offline anlauto
Re: advice on stubborn lower ball joint?
« Reply #1 on: September 03, 2016 - 09:10:46 AM »
You're pounding on the LCA around the stud of the ball joint correct ?
Try heat ?
Offline DadsCuda
« Reply #2 on: September 03, 2016 - 09:24:38 AM »
Try heat ?
yes...around it, but after also hitting the stud a couple times  :-[ ...would that have caused some issues?
is it possible to hit it too hard & throw the control arm out of whack? should i have the lower control arm supported with a jack or just hanging free?
Offline soundcontrol
« Reply #3 on: September 03, 2016 - 09:54:30 AM »
I would support it with something other than a jack, something more solid. Then some heat on the LCA. My T-bars was very stubborn, lots of violence needed.
And maybe spray some quick rust remover or similar and let it sit for a while first.
« Last Edit: September 03, 2016 - 09:57:48 AM by soundcontrol »
/ Ken
topic=108917.new#new
Offline rUNCHARGER
« Reply #4 on: September 03, 2016 - 01:09:45 PM »
If you can find a 3 or 2 jaw puller that will also work. Worst case have lots of pressure applied to the puller and smack the side of the control arm socket with a BFH and it will pop.
Sheldon
Offline DadsCuda
« Reply #5 on: September 03, 2016 - 01:38:38 PM »
 :pullinghair:seems like I'm doing the right things...just need to get more aggressive.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: September 03, 2016 - 02:06:56 PM »
Can you cram a picklefork in there and pry it off, otherwise heat and hammer.
« Reply #7 on: September 03, 2016 - 02:39:40 PM »
DO you nave a 4-5 lb sldge just swing it like a baseball bat
Offline DadsCuda
« Reply #8 on: September 03, 2016 - 02:56:59 PM »
I have a 5# sledge & I have a pickle fork. It's just not budging so I guess my impatience is getting the best of me.
...and I clearly need to work on my upper body strength!
Thanks for the input, as usual! :)
Offline 1 Wild R/T
« Reply #9 on: September 03, 2016 - 07:19:31 PM »
