Author Topic: What is this notch?  (Read 1206 times)
Offline rftroy
What is this notch?
« on: September 03, 2016 - 02:47:10 PM »
I've been measuring my Challenger wheel so that I can make an adapter from a Grant wheel to the stock crush can.
Been wondering why the factory wheel bolt pattern is offset, and noticed this on the crush can.
What is this notch in the crush can.  This notch is at the bottom center of the crush can.
Needed for assembly?
Line up feature?
Robert
« Last Edit: September 03, 2016 - 02:52:25 PM by rftroy »
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 blue;
78 Lil' Red Truck, Red;
70 Challenger S/E.  Soon to be 505 6 pack, Aluminum Hemi 4-speed, 3.55, Plum Crazy
Offline anlauto
Re: What is this notch?
« Reply #1 on: September 03, 2016 - 03:08:38 PM »
It's for the wire on a Rim Blow Steering wheel. :2cents:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: September 04, 2016 - 01:58:43 PM »
I guess so it can connect to this....
http://www.rimblowsteeringwheels.com/PICTURES.php
Offline rUNCHARGER
« Reply #3 on: September 04, 2016 - 07:20:35 PM »
The reason for the notch and bolt pattern is so that the steering wheel goes on in the correct position. Basically when the tie rods are adjusted correctly, everything lines up and when the wheels are pointed straight ahead the steering box is positioned midway  and the steering wheel will be perfectly centered as well, not off to one side.
Sheldon
