Finally got to the tuner to dial in the Megasquirt engine computer. Thanks to all for all the advice on my build.
504 HP and 541 Torque at the rear wheels. Dynojet 90 degrees outside yesterday and 80% humidity in Fort Lauderdale, FL
Adjusting for drive train losses at 15%, that's
580 Hp and 622 Torque at the flywheel.
The graph was recorded in MPH not RPM on this pull, so
40 mph = 1830 rpm
60 mph = 2750 rpm
80 mph = 3700 rpm
100 mph = 4600 rpm
120 mph = 5600 rpm
140 mph = 6500 rpm
Dyno Results for 505 Stroker
Eagle Stroker Kit. .030 over
TTI Headers, X pipe, Exhaust 3”
Dynomax Ultraflow
Lunati Hyd Roller Cam 20230712
.535 In .550 Ex Duration at .050 231 In 239 Ex RPM 2200 – 6200
PRW Roller Rockers 1.5
Edelbrock Performer RPM heads
Edelbrock Pro-Flo XT Intake Manifold
90 mm Throttle body, 55 lbs. injectors, Sequential fuel injection
Coil Near Plug running with Megasquirt 3 Engine Computer
Compression Ratio 10.8
Viper T 56 Transmission, Dynoed in 4th gear, 3.55 differential
Pump Gas 93 Octane
All in timing 32 degrees
Timing was original 36 degrees, moved to 32 degrees in increments and HP stayed the same, but torque increased 30 ft/lbs
Video of the pull
