Author Topic: Serpentine KitsWho is using what  (Read 3898 times)
Re: Serpentine KitsWho is using what
« Reply #15 on: September 08, 2016 - 08:15:42 PM »
That GM pump is common ( Corvette uses the same pump but with a bearing instead of a bushing ) I used it on mine. Here are a few pictures to see the tank mounted , its the same idea as the polished one just a welled/fabricated look. Top port in your picture is the pressure port.
Offline roadman5312
« Reply #16 on: September 08, 2016 - 08:16:06 PM »
                   I'll look up my notes in the morning.  I went thru hell researching this.   :hyper:
« Reply #17 on: September 08, 2016 - 08:17:21 PM »
Offline roadman5312
« Reply #18 on: September 08, 2016 - 08:43:18 PM »
:dunno:   https://www.summitracing.com/int/parts/bsp-77920
                               Yea, can go that way too.
Offline anlauto
« Reply #19 on: September 08, 2016 - 09:06:43 PM »
Yea not a lot of room unless I cut down the battery tray or something :pullinghair:
« Reply #20 on: September 08, 2016 - 10:00:46 PM »
How much room is there between the alternator and the water pump housing? Thinking you could utilize that empty boss on the water pump to bolt to?  :dunno:
Offline EbodyMod
  • Will it ever be finished????
« Reply #21 on: September 11, 2016 - 08:49:00 AM »
 :bigsmile: My battery is going in the trunk so the reservoir is a mute point for me!!! only issue i have is i already spent a bunch on a flow Kooler water pump and the want you to use the eddy pump with the kit.
:wavingflag:  Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
Offline EbodyMod
« Reply #22 on: September 12, 2016 - 11:36:41 AM »
 I appreciate the recommends guys, and after comparing everything multiple times I decided to go with the March "revolver" kit.  they all ended up at the same price with the same components (140 amp alt, p/s pump, water pump, a/c comp) but the march is clear powder coated.  I think that will be much easier to maintain, and I want to drive the wheels off this thing not spend all weekend polishing aluminum. :working:
Offline challenger4404spd
« Reply #23 on: September 21, 2016 - 11:34:41 AM »
maybe a little late to the party,  but here is the low mount ac sdconcepts kit.
Offline anlauto
« Reply #24 on: September 29, 2016 - 01:14:39 PM »
Okay...I bought the power steering reservoir that Brad found at Summit, except I opted for the smooth one, not ribbed (for her pleasure) and I bought the matching radiator over flow bottle. Kinda expensive, but real nice quality stuff.
While the car is in the metal shop I had Keith cut down the new AMD battery tray....
Offline EbodyMod
« Reply #25 on: October 03, 2016 - 01:43:59 PM »
That looks sweet! I think I am going the same route with mine. :clapping:
Offline AU6pack
« Reply #26 on: December 28, 2016 - 07:43:18 AM »
Hey Challenger440,
This is exactly what I'm looking for to go on my 340 to get the A/c compressor down low.
I've searched SD concepts but can't find the kit. Can you or anyone point me in the right direction?
Having a hard time finding a low mount a/c bracket for my small block.
Cheers
Craig
Melbourne, Australia
1970 Challenger 416 6 pak
Resto thread - http://www.cuda-challenger.com/cc/index.php?topic=114787.0
Offline Jamie
« Reply #27 on: January 05, 2017 - 11:13:55 PM »
Alan, what radiator/fan setup is that? Trying to find one I like.
I will finish a project.I will finish a project. I will finish a project.
70 barracuda plum crazy
( current goal is to keep just one car) AND FINISH IT!
08 charger r/t  w/road & track package
2011 silverado
Offline moprr
« Reply #28 on: January 07, 2017 - 10:54:41 AM »
 Looks like a champion radiator
