340 or 440?
Author Topic: 340 or 440?  (Read 3302 times)
Offline 4drbrnko
340 or 440?
« on: June 22, 2005 - 06:49:00 PM »
Wasn't sure maybe this goes in the engine section.  :dontknow:
My '73 is # matching, plan was to store the #'s motor and go with a stroked 340 set-up. The one I was considering was rated up to 500-600 hp and streetable.
My last trip home I went over to check on my dad's Torino at the mechanic and he said he had just picked up a '69 440HP with performance heads(?) and Eidelbrock intake plus some other stuff.
So, the big Q is should I consider a 440 swap instead of the stroker 340?
I don't want to do anything to the car that could not be easily changed back if I were to fully restore it.
If I stick in a 440 would I have to do any cutting or will it slip right in?
Thanks
Jeff
<-------<<<  Clickylinks..... My vehicles
Offline Carlwalski
Re: 340 or 440?
« Reply #1 on: June 22, 2005 - 07:06:19 PM »
Just new big block engine mounts. I'm also sure you may possibly need a Big block trans nell housing.  :???:
(How'd I do CP?)  :D :laughing:
Oh, and DEFINITELY go for that 440 thats the BEST year!!!!!!!!!  :drool:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline 4drbrnko
Re: 340 or 440?
« Reply #2 on: June 22, 2005 - 07:36:58 PM »
Yup, figured I'd need a BB 727 and new mounts, as long as the 440 will slip in without cutting anything.
I realy liked the thought of the stroked 340, but I think I can get the hp out of the 440 cheaper? (is there anything cheap when it comes to Mopars?)
Looks like I need to talk to my mechanic.
I just foung out about a factory replacement Hemi that's still sitting at a dealership that was ordered for a planned swap into a '72 Charger that never happened.............Hmmmmmmmmm.  ::)
Offline Carlwalski
Re: 340 or 440?
« Reply #3 on: June 22, 2005 - 07:42:35 PM »
Depend on how far you want to go?  :dontknow:
Just a clean out with fresh new parts and a shave of the clyindas (0.10 over)
Or all out hp monster which by the sounds of it is the way you want to go.
$3,500 is a good ball park figure. Chryco will fill you in and you may also want to check the tech archieves forum as I'm sure there is a rebuild or engine mods and prices etc. Basically what you can get and for what price. Hope I'm help.  ;D
(PS: That last post is meant ot be "B"ell housing.  :laughing:
Offline 4drbrnko
Re: 340 or 440?
« Reply #4 on: June 22, 2005 - 07:54:45 PM »
Yeah, I figured, your posts have so far to travel It's a wonder they aren't more garbled. Those trans continental internet lines can get crossed sometimes.   :eeksmall:   :laughing:
Thanks.
And yes, I would like to have a fairly hi output motor, but I still want to be able to drive it without twisting it in two........ that would suck.  :grinyes:
Offline Carlwalski
Re: 340 or 440?
« Reply #5 on: June 22, 2005 - 08:00:58 PM »
Thanks.
 :laughup: Yeah I'll say, it's quite awesome when you think of how far these words go to.  :o
Thousands and thousands of miles to your screen.  :eeksmall:
Yip, thats the way you want it, a mild to warm engine so it doesn't get hot.  :fire:  :beer:
Offline Burpin Chunks
  • http://mikescuda.net/cuda-challenger/burpin_chunks
Re: 340 or 440?
« Reply #6 on: June 23, 2005 - 12:42:04 AM »
Burpin is going to rebuild his 340 soon. What set up were you looking at to get the 500 horses.
CHRYCO do you know of a hot setup that Burpin can copy for his 340. It will need to run off of pump gas and beable to handle A/C. And besides the monster torque and power nothing else really matters. Its not a daily driver.
Re: 340 or 440?
« Reply #7 on: June 23, 2005 - 12:45:34 AM »
We built a really strong 360 , very streetable with 280 RWHP & dead flat power curve
Re: 340 or 440?
« Reply #8 on: June 23, 2005 - 12:48:39 AM »
Will that set up work with the 340. And burpin isnt use to RWHP terms. Tell it like the magazines would. How much HP that way.
Re: 340 or 440?
« Reply #9 on: June 23, 2005 - 12:49:53 AM »
over 400 gross HP in 70 terms , the 340 will be down on torque due to stroke or lack thereof
Re: 340 or 440?
« Reply #10 on: June 23, 2005 - 12:51:40 AM »
What compression was this set up. And if high compression would be beneficial to lower it to run blower.
Re: 340 or 440?
« Reply #11 on: June 23, 2005 - 12:54:41 AM »
close to 10 :1
 with a blower you Have to reduce compression ratio
Re: 340 or 440?
« Reply #12 on: June 23, 2005 - 12:56:13 AM »
right, but how much would I gain or lose by lowering it to run the blower. Burpin mainly just likes the look of the old type blower sticking out of the hood.
Offline 4drbrnko
Re: 340 or 440?
« Reply #13 on: June 23, 2005 - 11:37:30 PM »
Just heard back on the 440:  long block(1969), 2 sets of extra heads(906 and magnum) and a Torker 440 intake.
$500
Trying to get whether it's an HP block or not.
$500 seem about right for what I'd be getting?
I trust the guy, he's pretty straight when it comes down to it, he's just a big Chebby guy.
I'm just not up on prices for 440's.  :dontknow:
Also, I just need to "crank up " the torsionbars to compensate for the extra weight of the 440?
Offline 1973challenger360
Re: 340 or 440?
« Reply #14 on: June 24, 2005 - 12:04:23 PM »
the tortion bars are different.   I know someone who put a 440 in a scamp /6car the tortion bar snapped lucky for him it was sitting in the garage.
build the 360   and put the 340 decals on it.
Roots blowers suck  :ack:  its better to blow a carb than suck a carb. they do make blow through carbs now but there still ugly. unless you have air shocks, huge rubber out the side, and a 70's paint job.
Turbo-   they have rear mounted ones now. and prochargers/paxtons superchargers.
ok its a chevy site just look at the turbo set up/ and dont hit a bump.
http://www.chevyhiperformance.com/techarticles/148_0502_turbo/
