Author Topic: starter keeps running after starting  (Read 1350 times)
« on: September 11, 2016 - 10:04:45 PM »
So is the solenoid in the starter bad?
My friends truck.
Re: starter keeps running after starting
« Reply #1 on: September 11, 2016 - 10:33:37 PM »
Never mind. Figured it out.
Offline JayBee
« Reply #2 on: September 12, 2016 - 09:26:16 AM »
Please share. Was it the starter's solenoid? What did you do to stop it from spinning after start up?   Thanks.
John
1970 Barracuda convertible
2014 Toyota Avalon
« Reply #3 on: September 12, 2016 - 09:36:26 AM »
cable touching ground. I wasn't there. He found it.
« Reply #4 on: September 12, 2016 - 08:53:48 PM »
:clueless:
What cable touching ground would do that?
Offline mjb765
« Reply #5 on: September 12, 2016 - 09:12:07 PM »
:clueless:
Good question...was wondering that also
« Reply #6 on: September 12, 2016 - 09:58:00 PM »
:clueless:
Yeah I'm a little confused on that as well.
He told me that on the phone.
Offline mjb765
« Reply #7 on: September 13, 2016 - 08:28:12 AM »
I would ask him to show me that one.....
« Reply #8 on: September 13, 2016 - 09:31:29 PM »
So he said that he had an aftermarket battery cable he had.
The terminal where it bolts onto the relay has an elongated end on the terminal ring.
When he put it on, he had it twisted in a way where it was barely touching the small post on the relay.
Almost like when you try and start your car using a screwdriver you may picture doing.
