Author Topic: Fusible link Question  (Read 2276 times)
Offline Aussiedeza
« on: September 14, 2016 - 06:58:52 AM »
Hello, my alternator died on me a while back and i finally have the time and money to buy a new one.
After lots of looking and head scratching i purchased this guy https://www.summitracing.com/int/parts/pwm-7509/overview/ a 95 amp power master alt. So i figured while i wait for this new alternator to arrive i better do some wire upgrades to handle the higher Amps and disconnect the amp gauge out of the equation so my question according to a bunch of sources i need to run a 4 gauge wire from my new alt to the starter relay and a 4 gauge wire requires a 8 gauge fusible link am i wrong coming to this conclusion as i have been looking everywhere and I cant seem to find fusible link wire larger than 12 gauge..
Cheers guys would really appreciate being pointed in the right direction on this one.
Dan
1970 Challenger, 318
Perth, Australia
Re: Fusible link Question
« Reply #1 on: September 14, 2016 - 09:21:20 AM »
You don't need a 4 gauge wire for the bypass.  This link shows a 10 gauge bypass wire with a 14 gauge fusible link. It wouldn't hurt to run an 8 gauge bypass and a 12 gauge link.
http://www.madelectrical.com/electricaltech/amp-gauges2.shtml
You're higher amperage alternator won't put out any more amps then the stock alternator unless you've added extra electrical loads to the vehicle.  If you've added extra loads, that's when the wiring upgrades are needed.
Offline Aussiedeza
« Reply #2 on: September 14, 2016 - 09:39:38 AM »
Hi Burdar, thanks for your input mate the mad electrical link is what I have been using for reference and i should of mentioned that I have installed a few extras that would draw extra electrical load which is why i opted for a higher amp alternator this time as it was really struggling before for instance power windows would go up and down super slow and turn off the radio when pressed.
I figured the best plan would be to get the wire recommended for 95 amps and lots of sites show graphs like this one suggesting 4 gauge, if you think i can get away with using 8 gauge that would make my life easier sourcing a fusible link.
Dan
Perth, Australia
Offline lulurocks
« Reply #3 on: September 14, 2016 - 09:56:09 AM »
for the alternator:
Under 10' you need #6   with a #12 link
Over you Need #4 as per manufactures specs. with a #12 link
http://www.powermastermotorsports.com/charge_wires_a.html
for the bypass you need 8 with a #16 link
anytime you tap power you need a fuse or a link to protect the wire from an over-current fault or fault to ground.
« Last Edit: September 14, 2016 - 10:19:18 AM by lulurocks »
« Reply #4 on: September 14, 2016 - 10:00:22 AM »
The MAD article says to remove the factory charge wire from the alternator and to hook it up to the starter relay with a fusible link.  Personally, I would put a fusible link on the end of the factory charge wire and leave it hooked up to the alternator.(less wiring to do)  Then run your 8 gauge bypass wire.  This way, you are charging the battery with the bypass wire AND the original charge wire.  :2cents:
It's also been debated if you even need a fusible link on the bypass wire if you are running it directly to the battery or relay.
« Last Edit: September 14, 2016 - 10:02:23 AM by burdar »
« Reply #5 on: September 14, 2016 - 10:06:05 AM »
According to that chart, 85-105 amps can use an 8 gauge wire if it's under 7' in length.
Offline lulurocks
« Reply #6 on: September 14, 2016 - 10:22:34 AM »
all depending on his specific routing ....
Offline Aussiedeza
« Reply #7 on: September 14, 2016 - 10:47:32 AM »
Ok i just bought some 6 awg wire and some 10 awg fusible links, kinda wana try and neaten up the bay a bit so that should give me some flexibility with routing. thanks for the info guys.  :2thumbs: :2thumbs:
Dan
Perth, Australia
Offline lulurocks
« Reply #8 on: September 14, 2016 - 11:05:51 AM »
that will work for the alternator  ,  but the #10 link is too big for the bypass if you chose to do it , you are interfacing existing wiring at that point and your link needs to mirror the size of the link of what your essentially re-feeding .  again protecting the existing  harness wiring  ..
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #9 on: September 14, 2016 - 08:49:07 PM »
Ampacity has a lot to do with the type of wire you use... Some far exceed the NEC [National Electrical Code]
Best to stay away from crap wire from Home Depot or Lowes...
Power cables we use in Telecom DC power systems.
http://www.cobrawire.com/x-flex/x-flex150.php
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline jhaag
« Reply #10 on: September 14, 2016 - 10:31:10 PM »
Also might want to look at using relays for your power windows and other add ons.  :2cents:
love 70 Challengers
« Reply #11 on: September 14, 2016 - 10:50:01 PM »
While bigger wire is always better for current flow, those charts are for sustained current. Your alternator is usually putting out about 5- 15 amps. More at night. You're never pumping out 80-100 amps other than extremely briefly. If you are, you will be on fire.  :2cents:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #12 on: September 14, 2016 - 11:25:50 PM »
Can you imagine the sound system that would draw 100A, your car will melt down to a cinder but hell it will sound *****in!!!
