Author Topic: k member id, anyone know what a 12 coin on e body k mbr means???  (Read 2928 times)
Offline hemimaster
  • Newbie
« on: September 15, 2016 - 08:28:54 PM »
have a factory k member with a 12 embossed on the front coin attached at the factory and would like to know if it means anything? Thanks!
Re: k member id, anyone know what a 12 coin on e body k mbr means???
« Reply #1 on: September 15, 2016 - 10:06:23 PM »
The # on the coin is the last two digits of the part number. 12 refers to early 1970 E-body 318,340 and 383. No skid plate.
Offline hemimaster
  • Newbie
« Reply #2 on: September 15, 2016 - 11:01:28 PM »
Thanks! but are you saying a small block and big block k member is the same in all non V and R and TA coded cars?
Offline Cuda Cody
  • Vancouver, WA
« Reply #3 on: September 16, 2016 - 12:30:57 AM »
1970 V and R codes (Hemi and 440 six pack) got a skid plate on the bottom of the K member.  Hemi has a special K member (14 or 76 stamped coin) and V codes were a standard V8 K member with skid plate (77 or 74 stamped coin).  T/A & AAR received a non skid plate K member (like all of the K members) with a coin stamp of 52 (also used in 318, 340, & 383's).
Offline anlauto
« Reply #4 on: September 16, 2016 - 06:25:27 AM »
To simplify...YES Big block and Small block can use the same K member. Hemi and six cylinder can not. :2cents:
Offline RzeroB
  • In The Lou and looking for a new (old) ride
« Reply #5 on: September 16, 2016 - 11:52:47 AM »
Looked at a '68 Barracuda Formula S 340 last month and the seller mentioned something about a "washer" on the k-member but then couldn't find it. "Washer", "coin", the same thing I suppose. So where on the k-member is this "coin" typically attached? Thanks.
Cheers!
Tom
St Louis, MO
Former owner of 16 classic Mopars. "It is better to have owned (Mopars) and lost then to have never owned at all" (apologies to Alfred Lord Tennyson)
Offline RzeroB
« Reply #7 on: September 16, 2016 - 12:38:34 PM »
thanks Darren :cheers:
Cheers!
Tom
St Louis, MO
