Author Topic: 440 Spark Plug Wire Routing  (Read 4544 times)
Offline dave73chally
« on: September 16, 2016 - 10:09:53 AM »
How do you guys route your spark plug wires on a 440 with headers? I have a couple options, some involve cutting. But before I do anything, who has some pictures??
FWIW I have MSD 8.5 wires with straight boots. They can be bent to about a 45*. Currently it's way to tight around the steering shaft and a few other areas.
73 Challenger
Offline HP_Cuda
  • Mopar or No Car!
Re: 440 Spark Plug Wire Routing
« Reply #1 on: September 16, 2016 - 01:48:36 PM »
Bend em like Beckem!!!
I have the MSD 8.5 wires as well and use a wire loom kit.
Offline cudabob496
« Reply #2 on: September 16, 2016 - 01:56:27 PM »
I custom cut the length of mine
have them come up from under the header when possible
2011 Kawasaki Z1000
« Reply #3 on: September 16, 2016 - 03:12:04 PM »
Do you have some pictures of how they run through the headers? So you didn't cut anything just bent them? My 5 and 7 are really close to the steering shaft. And 4/6 are really tight against the shock tower. Did you use a loom kit with brackets that hold the wires up off the headers/valve covers etc?
73 Challenger
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: September 16, 2016 - 03:29:23 PM »
For the steering shaft I bent mine at a nearly 60 degrees.
You can seem one of the looms to the left.
Here is a pic:
« Reply #5 on: September 16, 2016 - 10:32:43 PM »
In addition to the above suggestions I used these also.
https://www.summitracing.com/int/parts/sum-350119
« Reply #6 on: September 19, 2016 - 08:27:41 AM »
Yup I have a set of those being delivered today. I may get some 90* boots and cut and fit some of the wires if I can't get them routed clean enough.
73 Challenger
« Reply #7 on: September 21, 2016 - 10:35:51 PM »
Ended up using an msd wire loom, bending some look brackets I had and...don't cringe a bunch of black zip ties for a really clean look. Really surprised how well the zip ties worked and blended in with the black wires. Just need to raise the wires running on the manifold and call it a day.
73 Challenger
Offline cudabob496
« Reply #8 on: September 22, 2016 - 03:49:01 AM »
I have the four wires that are going to the right of the carb in your photo,
going to the left of the carb, though the wire for #1 plug goes under the water pump.
2011 Kawasaki Z1000
« Reply #9 on: September 22, 2016 - 07:51:24 AM »
Get rid of that plastic fuel filter.  :2cents:   Fire hazard IMO  :wave:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: September 22, 2016 - 12:06:52 PM »
As Brad says, that wouldn't pass tech inspection.
Run the fuel filter at the rear with a can like this. I know you cannot see when it's clogged but its the best way as I have had others that just started leaking on me.
« Reply #11 on: September 22, 2016 - 12:30:24 PM »
Thanks guys. Just picked up a new filter so I'll replace the plastic one.
73 Challenger
Offline 70chall440
« Reply #12 on: September 22, 2016 - 12:33:07 PM »
 You should take a look at one of these to get your heater hoses out of the way
http://www.ebay.com/itm/like/291676881795?lpid=82&chn=ps&ul_noapp=true
 :bigsmile:
Current Mopar
Past Mopars
« Reply #13 on: September 22, 2016 - 12:55:50 PM »
 :2thumbs:
« Reply #14 on: September 22, 2016 - 11:23:42 PM »
I like the clean / simple black steel valve covers , I would have swapped left to right & had a short run to the PCV & the breather at the front .
