Author Topic: ignition help  (Read 1995 times)
Offline BadJoey
ignition help
« on: September 16, 2016 - 09:48:53 PM »
Here is where I'm at .70 440 Challenger making around 430 horse . Been playing a little and now I want a high rev limiter . The stock Dodge electronic ignition seems to work fine now .Could I hook up a rev limiter to whats there now or do I have to change everything . Would there be much of a horse power gain with a performance ignition over stock ? Not looking to spend too much . Any good kits for sale with everything . Also keep in mind I'm a back yard guy so nothing too complicated please . As always Thanks in advance and look forward to some thoughts .  :2thumbs:
Re: ignition help
« Reply #1 on: September 16, 2016 - 09:55:02 PM »
What ignition box are you running now?  I think the orange box is only good to maybe 5000rpm.   I have no experience with it but there is a bolt-on ignition box that has a built-in regulator feature.  Look for posts talking about the Rev-N-Nator.
Offline blown motor
Re: ignition help
« Reply #2 on: September 16, 2016 - 10:11:23 PM »
 :iagree: I have a Rev-N-Nator. It works great.
http://www.thertgarage.com/products.html
Offline BadJoey
Re: ignition help
« Reply #3 on: September 16, 2016 - 10:56:19 PM »
Just looking at the Rev n nator my question, if any how would horse power be affected compared to say a msd set up .  I'm thinking horse powercompared to cost hope to do this only once parts cost a lot .
In other words If it's worth the gain I'd rather put the $400.00 towards the better set up . Up to a limit .
Offline barnett468
Re: ignition help
« Reply #4 on: September 16, 2016 - 11:13:57 PM »
you wont gain any hp over using any multi spark box . you gain a little with any of these boxes and they clean up the idle a little on engines with big cams . if you want a noticeable increase in power you need to change something big.
Offline 7212Mopar
Re: ignition help
« Reply #5 on: September 17, 2016 - 01:51:02 AM »
Yes it works great for my car too.plan to keep it whenever my engine goes back in.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Offline tman
Re: ignition help
« Reply #6 on: September 17, 2016 - 03:34:57 AM »
I have to say, with the Rev n Nator + Firecore distributor, my car runs much better compared to the MP performance Electronic ignition conversion kit.  Its on a 440-6.  I did happen to get their coil too.  I purchased the distributor separately.  At the time, they did not offer the pkg with distributor.  I just got the coil and ECU.
The Rev unit is basically for those who wishes to have the stock look.  If that is not your desire, then by all means, get the full MSD or other system.
Offline 73440
Re: ignition help
« Reply #7 on: September 17, 2016 - 06:58:14 AM »
I have the Rev-N-Nator with the recommended Accel distributor and works well.
I did have to change the starting position of the firing order on the Accel cap as the tenon into the distributor gear it didnt match the points distributor being replaced. Different relationship of the tenon to the relutor angle.
I also have the MSD full kit to put in one day, just thought the Rev-N-Nator would be easier to do first.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline BadJoey
Re: ignition help
« Reply #8 on: September 17, 2016 - 09:35:28 AM »
Found this forum when looking for information. They claim a 10 too 40 hp gain with the rev n nator over a stock set up . See what you think .
http://board.moparts.org/ubbthreads/ubbthreads.php/topics/1117319/updated-dyno-results-on-the-rev-n-nator.html
Re: ignition help
« Reply #9 on: September 17, 2016 - 10:19:25 AM »
 :canada:
 :iagree: Multi spark only goes up to 3000 rpm & then goes back to single spark output , if you do a full tune up Before switching to MSD it might start easier but you will gain zero HP , the gain is made in the ECU switching speed so a Revnator is a good upgrade , if you really want to up grade go to a crank trigger & 4 coil packs
