Author Topic: Door Latch  (Read 1947 times)
Offline DirksCuda
Door Latch
« on: September 18, 2016 - 08:16:36 AM »
I need a door latch with the rod for the drivers door of a 70 Cuda. Others may work let me know what u got Thanks
Offline brotow
  • There really is a Challenger in the backround
Re: Door Latch
« Reply #1 on: September 19, 2016 - 06:05:44 AM »
Do you need the part that is in the door that closes on the striker1/  And the rod that goes to the inside handle, outside handle or the lock rod? I should have those parts from a 1974 chall
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline DirksCuda
Re: Door Latch
« Reply #2 on: September 19, 2016 - 06:43:44 AM »
Hi Brotow in need the part that goes inside the door held in with 3 screws. I would take all the rods, I don't know what is missing, someone stole it while the car was sitting. I'm in Canada so let me know how much with shipping Thanks Dirk
Offline anlauto
Re: Door Latch
« Reply #3 on: September 19, 2016 - 06:55:39 AM »
Whereabouts in Canada ?
Offline brotow
Re: Door Latch
« Reply #4 on: September 19, 2016 - 10:01:20 AM »
[/quote
I'll get some pictures for you
Offline 4 speed fish
Re: Door Latch
« Reply #5 on: September 19, 2016 - 10:56:10 AM »
70 door latches are different from the other years.
Re: Door Latch
« Reply #6 on: September 19, 2016 - 11:19:16 AM »
In 1970, you can't lock the door from the inside and then close the door.  The latch will unlock.  The door needs to be locked with the key from the outside.  Later year latches should still bolt in place and work.
Offline brotow
Re: Door Latch
« Reply #7 on: September 20, 2016 - 06:34:47 AM »
Here are some pictures. The latch was blasted and powder coated, needs to be greased before use. I found the two long rods I also should have the plastic clips I haven't found the two short rods yet. They may have been sold with the outer handles.
http://s1308.photobucket.com/user/glennrossano/library/1974%20challenger%20drivers%20door%20latch?sort=3&page=1
Offline DirksCuda
Re: Door Latch
« Reply #8 on: September 20, 2016 - 07:18:24 AM »
Thanks Brotow I'm in Ontario Canada N0P1W0
Offline anlauto
Re: Door Latch
« Reply #9 on: September 20, 2016 - 07:34:36 AM »
That's pretty far....I was going to say stop in and look through what I have....I have lots of door stuff kicking around...
Offline brotow
Re: Door Latch
« Reply #10 on: September 20, 2016 - 08:36:27 PM »
Oww, my toes
Offline DirksCuda
Re: Door Latch
« Reply #11 on: September 21, 2016 - 06:33:42 AM »
Thanks guys I found 2 not to far from me
